Internal throttle question
Old Oct 2, 2011 | 05:43 PM
rlo1's Avatar
rlo1
Default Internal throttle question
I'm waiting for some apes from BR and was thinking internal throttle, I've followed a few threads on here about bars and thier's a lot of great info, but what internal throttle is the best and easiest install?
Thanks in advance
Old Oct 2, 2011 | 05:55 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
I just installed the Exile version. Just got back from an 800 mile rip. This thing jams. Are the bars you installing 1.5" or 1.25"? I have not installed any other internal throttles so I only have experience with the exile version.
Drew
Old Oct 2, 2011 | 06:58 PM
Fireman1501's Avatar
Fireman1501
I used the Steamline version. They said it would work with the stock switch housings but I had to modify it to make it work the way I wanted it to look.
Old Oct 2, 2011 | 08:23 PM
rlo1's Avatar
rlo1
Dr.v, I went with the 1.5 stepped down to 1, how was the install?
Fireman1501, I looked at the streamline, what problem did you run into? is it true they work with any grip and any cable as advertised ?
Old Oct 2, 2011 | 09:32 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
The bars are very thick and had to be ground down on the inside for the throttle to fit in. Lots of dremel work. I also had to have the throttle welded into the bars due to the dimpling for internal wires. It work s great and was well woth the labor. It would be a great winter project if we had winter here. You can read more about it here.
https://www.hdforums.com/forum/softa...ml#post8883895
Drew
Old Oct 2, 2011 | 11:45 PM
poppavein's Avatar
poppavein
Drew
Is jamming a good thing or a bad thing? I don't understand you kids these days ...
Old Oct 2, 2011 | 11:53 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Let me rephrase. It works great. No issues.
Drew
Old Oct 3, 2011 | 02:30 PM
rlo1's Avatar
rlo1
can you only use exile grips with their throttle?
Old Oct 3, 2011 | 03:00 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
You can use any grips you like. I got exile as they were pre machined for my grip ace and in stock ready to go when i walked in the door. I really dig the polished knurled grips. They are super comfy.
Drew
Old Oct 3, 2011 | 08:34 PM
Fireman1501
Internal throttle setups require machined grips made for internal throttle setups. The factory style grips will not work on the stream line setup. My grips have Allen set screws holding them on and they fit the throttle set perfect.
