Windshield
Old Oct 3, 2011 | 01:32 PM
Kurtchambers's Avatar
Kurtchambers
3rd Gear
Default Windshield
I'm new to the Harley Family. I just bought a 2003 FLSTC and need advice on a windshield. The previous owner put a nacelle on the front and a stock softail windshield won't fit. The mounts are right but the shield hits the headlight..What are my options? I tried a Road King shield but the mounts aren't correct....
Thanks,
Kurt
Old Oct 3, 2011 | 01:51 PM
fdb2007's Avatar
fdb2007
If you have some skills, patience and dremel or other fine cutting tool, you can trim the windshield. If it isn't a lot you might be able to do it by hand with some sandpaper, but again it takes some skill and patience. Measure twice, cut once and remember you can take more off, but you can't put it back on. The windshield is made of polycarbonate and it is not gonna crack, but you can sure scratch it up. Mask it off before you start marking and trimming. Good luck.
Old Oct 3, 2011 | 05:00 PM
gooberdog's Avatar
gooberdog
Or you can buy a new windshield. Either one of these will fit.
HD 58649-97A
HD 58651-97A
Old Oct 3, 2011 | 06:37 PM
oc1014's Avatar
oc1014
If you already have the stock windshield just cut it to fit, Its not hard just take your time.
Old Oct 3, 2011 | 06:43 PM
Kurtchambers
3rd Gear
Thanks for the advice..Looks like a new one is in the works...
Old Oct 3, 2011 | 06:51 PM
oct1949's Avatar
oct1949
I've cut my shield down twice, Several threads in here on how..
If U do, just be careful on U layout and sneak up on it, also make sure U tape off area real good to prevent scratching the shield.
I used a Roto-zip. cuts the sheid like butter..
Others use saber saw.
Old Oct 3, 2011 | 07:05 PM
Kurtchambers
3rd Gear
I don't have a shield or I would give it a try..Just wanted to make sure they have one and I buy the right one...Thanks!
Old Oct 3, 2011 | 07:13 PM
purecountry13b's Avatar
purecountry13b
If you do get a new one, take a look at the Flair windshield by Klock Werks. My buddy has one and says it's the bees knees.
Old Oct 4, 2011 | 01:44 AM
tmac00333's Avatar
tmac00333
Windvest!
ttikalsky
Jun 5, 2010 10:44 AM
Hellanbach
Mar 26, 2010 07:58 AM
Chips
May 9, 2009 09:47 AM
winnhog
Jul 7, 2007 07:15 PM
