Mikuni 42
Old Nov 1, 2011 | 07:19 PM
olongapo1's Avatar
olongapo1
Default Mikuni 42
I have a Mikuni 42 on my Night Train. Purchased it from Harley under their Screaming Eagle line as a kit. This carb has been a great performance improvement over my old stock CV. I need to replace the choke cable so it's the perfect time to make modifications while the carb is off the bike.
Looking for performance recommendations from Mikuni users. Note: I do not know what jet sizes are in the carb.
Old Nov 1, 2011 | 07:41 PM
magnum629c's Avatar
magnum629c
what kind of pipes and filter u runnig?
Old Nov 1, 2011 | 07:48 PM
olongapo1's Avatar
olongapo1
Additional Info. Running a Big Sucker Stage 1 Intake and Bassani Pro Pipes with Big City Thunder Baffles.
Old Nov 1, 2011 | 07:49 PM
mimo's Avatar
mimo
If you're all set with intake and exhaust, coil, ignition module, etc. Next would be cams, It is my next step, looking into the Andrews EV 27...
Mimo.
Old Nov 1, 2011 | 07:54 PM
05FLHTC's Avatar
05FLHTC
If yr milage is decent 40ish I wouldn't touch it.
If yr motor is a TC & if yr getting low 30's then I would suggest dropping the needle (97) so it's a notch lower then the middle setting, drop the pumpjet down to a 50 with a 20 pilot & 165 main. Set the pumpjet up so the on plastic neural has the width of a dime between it & the rod & set the off adjustment so it's flush with carb top. Then readjust the idle AF screw, should end up about 1~1.5 turns or so out from seated.
The Miks normally come a tad fat out the box. These changes should improve the milage & IME the throttle response will be crisp.
HTH's
ramblindan
May 2, 2016 10:25 AM
badwiser
Jun 3, 2010 10:07 AM
r6danl
Exhaust System Topics
Aug 24, 2008 09:16 PM
wrustywrench
Apr 18, 2008 02:06 PM
johno1978
16
Mar 25, 2006 10:49 AM
