Relocate Rear Brake Reservior?
Old Nov 7, 2011 | 06:34 PM
tmd442's Avatar
tmd442
Default Relocate Rear Brake Reservior?
My 97 FXSTS rear brake reservior is located between the down tubes below the voltage regulator.
I installed pipes last year and the O2 Sensor port (which is plugged) actually touches the top of the reservior.
Well when I removed the front pipe to check the fluid level (yes the pipe needs to be removed to take the cover off) I noticed that the fluid level was very low.
No leaks in the rear brake system, check the caliper and all the brake lines.
Checked the specs on DOT 5 and the boiling point is 500 deg. So I think that due to the front pipe being so close it's getting too hot and boiling it off?
Not sure if I should try to relocate the reservior or cut the O2 sensor bung and weld it closed.
Seems all the pipes I look at now contain the oxygen sensor port. So What are my options?
Help
kingironhead
Jul 15, 2014 03:01 PM
aokpops
Sep 8, 2012 11:35 PM
shamrock63
Jul 22, 2011 02:26 AM
SBJJC
Feb 21, 2010 01:19 PM
dkingiii
Jan 8, 2007 07:22 AM
