Front Turn Signals
Old Nov 29, 2011 | 10:47 AM
TheGENERAL412's Avatar
TheGENERAL412
Default Front Turn Signals
Is it a law that you must have front turn signals on your bike? I have seen a few pics of bike where there are no turn signals up front and was curious since I want to move mine off the handlebars and down onthe forks somehow. If I dont need them at all then I will just look at taking them off, otherwise I need to figure out my options for moving them down.
Thanks in advance,
Jim
Old Nov 29, 2011 | 10:52 AM
tkunk's Avatar
tkunk
It varies by state. I know the ABATE website has a link to all the different states motorcycle laws. Here in Minnesota we don't need any blinkers, just one mirror, a headlight with low/high beam and a rear run/stop light.
Old Nov 29, 2011 | 11:35 AM
tkunk's Avatar
tkunk
Thanks in advance,
Jim
Found it. They are not required in PA.
http://www.cmsnl.com/community/misc/...t=Turn+Signals
Old Nov 29, 2011 | 12:40 PM
Mikey05's Avatar
Mikey05
I would double check with your dmv. I did a quick search for my state, utah, and it said i didn't have to run them.. but i know for a fact they check them in the safety inspection. The state didn't pass my buddies honda because of a burned out bulb.
Old Nov 29, 2011 | 12:52 PM
bcrdb's Avatar
bcrdb
Some states that do not require turn signals require them to work if you have them.
Old Nov 29, 2011 | 01:07 PM
Mikey05's Avatar
Mikey05
True. but as i looked more into it i found this..
This was taken from the UTAH 2009-10 official vehicle safety inspection manual for motorcycles.
"C. TURN SIGNALS
1. Check turn signal operation for proper functioning.
a. REJECT when:
1) Turn signals are missing when required. (After January 1, 1973)
2) Turn signals fail to function properly.
3) Turn signal lamps do not indicate amber to the front and red or amber to the rear.
*NOTE: When a motorcycle is originally equipped with turn signals, they must be present and function as designed by OEM.
*NOTE: All motorcycles manufactured after January 1, 1973 must be equipped with turn signals
(49 CFR 571.108), (UCA 41-6a-160i(c))."
Id check with the local DMV before I payed a ticket.. or at least so i was aware of what i was doing.
Old Nov 29, 2011 | 03:02 PM
TheGENERAL412
Excellent stuff guys! Thanks so much. Checking and I found on the PA DMV Site, thanks to all of your input, that FRONT turn signals are NOT required.
BruceI
2014-2024 Touring Models
May 24, 2018 09:08 AM
kgschlyer
Electrical/Lighting/Alarm
Apr 6, 2016 07:14 AM
ed gien
Apr 16, 2011 11:51 PM
BigLowRider
Jan 6, 2009 08:45 AM
Soarer
Jan 11, 2007 10:27 PM
