Said it b4 and will say it again "what is it with you USA guys and your bloody horns? more noise more man hood?
I hated that stupid thing hanging over my engine.
I went on e-bay bought a 12v horn from china for about $3 stuck it behind the seat under rear fender sounds like a Leprechaun fart but who cares?
Just curious if anyone has relocated their coil to the horn location with the outputs pointed vertical and then adapted an aftermarket horn cover to hide the coil?
The reason I ask is that it seems like there is a much larger selection of horn covers than coil covers.
wolo under the stock cowbell, ya gotta separate the horn from the compressor,, it's pretty easy to do, just get creative & make it work,,, use a relay & it's louder than ***
Very nice. Did you locate the compressor above the voltage regulator? Little hard to tell from the picture.
