Installing exhaust gaskets
Old Dec 13, 2011 | 04:28 PM
jharanin's Avatar
jharanin
Default Installing exhaust gaskets
I know somebody out there has an easy way to install exhaust gaskets when replacing pipes...I was starting to use a block of wood around the same size..before I started I thought I would ask the forum.
Old Dec 13, 2011 | 05:30 PM
beasleyiv's Avatar
beasleyiv
If using the crush gaskets, a little WD-40 and work them in with your fingers. If using the SE gaskets, just work them in. I switched to the SE's, much easier to put in.
Old Dec 13, 2011 | 05:32 PM
soft 02's Avatar
soft 02
Try using a large socket and tap them in with a rubber hammer.
Old Dec 13, 2011 | 07:19 PM
2012Fatso's Avatar
2012Fatso
I switched to the SE gaskets and they went in very nicely.
Old Dec 13, 2011 | 07:24 PM
jharanin's Avatar
jharanin
Thanks for the advice..I think I'll try the WD40 first. At $8 each don't want to experiment much.
Old Dec 13, 2011 | 07:27 PM
jharanin's Avatar
jharanin
If they give me much trouble I'll be switching to the SE too. Asked the parts guy when I bought the crush gaskets what the difference was, he didn't have a clue.
Old Dec 13, 2011 | 07:36 PM
dieselguy65's Avatar
dieselguy65
i always just pushed them in with my fingers,its exhaust gasket, not 'rocket surgery' lol
Old Dec 13, 2011 | 08:12 PM
TheTroupe's Avatar
TheTroupe
The SE gaskets do not work with most pipes. Check the recommendations on your manufacturer. Then look at http://www.jimsusa.com/tools.php
Old Dec 14, 2011 | 05:37 AM
Jaburg1's Avatar
Jaburg1
Be careful with the SE gaskets because they don't always seal. I made the mistake of using them only to find I had leaks at each header until I re-read the instructions on my Rush pipes and saw they specifically said to use the stock tapered gaskets because the other style will not seal....my bad. Just be patient and they'll work into the exhaust port. Place them in and squeeze a little here, a little there....pushing in as you go around. I'd be leary about using any lubricant to help out not knowing how it'll react to the high heat levels when the engine is running. Re-installing pipes is a Royal Pain.
Old Dec 14, 2011 | 06:05 AM
jharanin's Avatar
jharanin
Thanks fellas...diesel guy keep your day job.
