Rev limiter
Old Dec 17, 2011 | 06:31 PM
zxgto06's Avatar
zxgto06
Default Rev limiter
Hey guys I got a question.. My 2002 fat boy has the 95in sceamin eagle big bore, doesn't look like it has any kind of performance ignition on it, so my question is does the bike have a factory rev limiter? If so what is it?
Old Dec 17, 2011 | 08:17 PM
zxgto06's Avatar
zxgto06
55 views and no one knows?! Man it must of been a good question!
Old Dec 17, 2011 | 09:01 PM
chiefe's Avatar
chiefe
I believe stock is 5500 and the SE module is set for 6200.
Old Dec 17, 2011 | 09:15 PM
zxgto06's Avatar
zxgto06
Ok so it does have a factory rev limit. Thanks that's what I wanted to know.
Old Dec 18, 2011 | 08:24 AM
TheTroupe's Avatar
TheTroupe
There is a rev limit on stock electronic ignition bikes, I believe it is 5700(?). Stage-1 air cleaners, installed by the dealer usually include a reprogramming and raises the limit to 6200.
Old Dec 18, 2011 | 08:15 PM
zxgto06's Avatar
zxgto06
Thanks guys. Just wanted to make sure this thing wouldnt over rev!
It's hard to get used to no rpm! My last bike redlined at 14K!!
Old Dec 18, 2011 | 10:02 PM
DevilDogg's Avatar
DevilDogg
You can get a direct replacement from HD or Dakota Digital that has an RPM gauge.
Old Dec 18, 2011 | 10:17 PM
Bluehighways's Avatar
Bluehighways
For Screaming Eagle Ignition Modules used in Kits: 31713-01 and also 32724-01; the rev limiter is set at 7,000 rpm. Google "Screamin J02070" and you will find a pdf copy of the Instructions for these Ignition Kits/Modules. I have the Ignition Coil and Ignition Module for this kit on my 2003 Low Rider.
Here is a link to the above Instruction sheet:
http://www.harley-davidson.com/en_US...ts/-J02070.pdf
Old Dec 19, 2011 | 02:30 AM
caaraa's Avatar
caaraa
Old Dec 19, 2011 | 06:01 AM
RICHIEMACK's Avatar
RICHIEMACK
Its stock at 5500,that is if the harley ignition has not been changed.by the time you red line in 5th you will be doing way over 100.no worries
