Yes, you can bump start a FI bike as long as all systems are working. Now, if for some reason the fuel pump is not working when cranking, no it won't start because there has to me enough pressure at the injectors to spray fuel to the cylinder. I have had to bump start my 2007 Sprortster 1200C Custom a few times when the battery was too low to crank but had enough to power everything else. Don't know what would cause the OP's problem but just had to put my two cents in as to whether or not it is possible to bump start an FI equipped Harley. After all, cranking the engine over with the starter is no different than cranking the engine over with the drive train via the tire and drive belt. They both turn the engine and thus the crank position sensor etc. etc.
sounds like your fuel pump or ignition may be getting its power cut off while your hitting the start button. grab a test light and troubleshoot
this makes sense. if you are losing power/voltage, you may want to give the ign switch connector a quick look. i've seen others here with connector melting issues. if the connector is melted, it may have melted to the point of enough resistance that would still allow amp draw operation, but when cranking the engine, the starter pulls more amps and can drop volt/amp supply to the ecm and sensors.
+1
Originally Posted by DyNaBoB
lol.. how do you roll, bump start a fuel injected bike??? not with a crank position sensor....if that was the case us fi bikes could run a kick start tranny......not possible
FI bikes push start fine as long as the battery is not dead...the only thing keeping you from kick starting it is the ignition...it does not fire on the first rotation...I am surprised that the aftermarket has not come up with a simple fix for that.
dang your in CA can you make a vid quick to show me (us) how you roll start your fuel injected bike..............
roll down a hill to build up some speed, kick it in gear (i choose 2nd) and dump the clutch with ignition on. It takes a moment to work sometimes, thats why its easier on a hill so you can dump clutch and keep rolling until it kicks over
What's interesting is that roll starting works but crank starting doesn't. Either way there must be power to all systems and the CPS has to send the timing info to the ECM. There are two differences that I can think of right away for a roll start... the bike isn't in neutral when it starts and the starter circuit isn't involved. Since I can embarass the heck out of myself by trying to start the bike in gear, then on my bike it must be the starter circuit and not a kickstand sensor or neutral safety switch (don't know what model or year you are riding).
I don't understand how a bump start can make up for no fuel pump pressure, either.
You may not be getting enough power to the ECM due to the starter load. I would start with connections and power tests.
I think it's probably the battery. It might sound like it's cranking fine, but check and see how much the voltage drops when you crank it. If the voltage drops too much while it's cranking, it won't be enough for the EFI.
Have you tried topping off the battery with a charger before trying to start it? When batteries get old it's not uncommon for them to lose some cranking power after a week of sitting.
lol not with a crank position sensor....if that was the case us fi bikes could run a kick start tranny......not possible
Can you please explain why a motor with a CPS can't be push started or kick started? Did you know that even the carbed TC motors use a CPS?
I do plan to get a new battery next season, but id never pin this issue on the battery because the crank sounds strong. Could it be a fuel pump issue?
thanks
I'd be happy if it were a battery issue, since as i said i know mine is on its last season. But it just doesn't make sense if its cranking like crazy.
cables are tight, anything else i can check?
Get an HD battery tender for those long storage periods. It even comes with a set of jumper cables. If you have the original battery in that bike, it's probably time for a new HD replacement battery. Use the old one for a doorstop
