If you can't find it, off hand I believe it's 14-21 ft lbs on the drain plugs. My manual is in the garage and it's cold. Way less on the primary cover something like 84-104 inch pounds--especially do not overtorque that one. Hand tight + a quarter turn will get you close, but I prefer a torque wrench. Get ready to get flamed on buying a service manual. Good luck, it's not rocket science.
I've always tightened oil plugs by feel vs. torque...getting a big arm you can crank leverage onto can cause trouble. Just remember how snug the plug felt when removed & tighten same...JMO, but have yet to strip one...
