drag bars electical problems please help
Old Jan 1, 2012 | 03:17 PM
eksofttail's Avatar
eksofttail
Default drag bars electical problems please help
ok so i got all the parts to switch over from stock buck horns to drag bars, with new switch housing etc. well i tried that chrome braiding over lay on wires and cables. so i had to cut and splice the buttons to get the braiding over the harness. no problem i was very though sodering and shinkwrapping each wire before returning buttons in new housings. well got the whole thing together and no blinkers ,no horn, and no spark.,
what the f--k
ok took it all back apart to check for crossed wires but everything is matching up to stock.
hope that i didn't some how burn up ecm
any help would be great
thanks
Old Jan 1, 2012 | 03:48 PM
Joe What's Avatar
Joe What
Multimeter time. First make sure you have juice going to switches then check if juice is leaving switches. This way you eliminate each switch one by one. I had similiar problem found it was a bad micro switch.
But first battery cable? Check fuses
Old Jan 1, 2012 | 04:37 PM
eksofttail's Avatar
eksofttail
yeah that's what i was thinking. thank's will try tomorrow.
Old Jan 1, 2012 | 05:29 PM
dieselguy65's Avatar
dieselguy65
why cut wires? take them out of the plugs and reinstall back in same place,
heatmizer
Apr 8, 2017 05:53 AM
GreenHorn
Electrical/Lighting/Alarm
Feb 25, 2014 09:45 AM
Figstr
Feb 8, 2012 05:05 PM
RaceFace
Sep 19, 2010 02:05 AM
dewnasty
Aug 20, 2008 04:19 PM
