New fatboy problems
Old Jan 6, 2012 | 08:42 PM
Smorris3480's Avatar
Smorris3480
Default New fatboy problems
Okay I just picked up my 2012 fatboy three days ago and it finally got out of the thirtys and the road dried up so I rode it today and I noticed that it is really hard to get it into neutral. It just gies straight to second from first. And when I do start it from neutral and shift down to first it gives a hard jerk forward. It is like I don't have the clutch puled in all of the way but I do. Idk if I need to adjust the clutch cable or what? I don't wanna take it back to the dealership if it is something simple cuz it willmtake them 2 weeks to look at i am sure. Any opinions would be great!
Old Jan 6, 2012 | 08:44 PM
Smorris3480
Sorry about the spelling. This yuengling is starting to get to me. Oh and I went from a sportster to the fatboy and besides the clutch problem it is amazing. I would have never imagined how much of difference there is in the ride. It is like riding on a lazy boy compared to the sporty.
Old Jan 6, 2012 | 08:46 PM
Rakthi's Avatar
Rakthi
It's cold, the oil in your primary is thick and the clutch plates stick to one another. Just let it idle a bit so the oil to becomes warmer. No need to adjust clutch.
(Just for info, I live in the tropics, and with bike in 1st and clutch pulled in, I have a hard time moving the bike due to clutch plates sticking/dragging when oil is 'cold' - also get a bit of jump forward when putting in 1st sometimes ... only at first start, once bike/oil is at operating temp everything OK)
As for neutral, i find it easier to go from 1st to neutral. Also bike is new, give it some time.
Old Jan 6, 2012 | 08:50 PM
TORQUEY's Avatar
TORQUEY
First of all, this problem goes away after a few hundred miles TO SOME EXTENT. This is not a commercial, but I have found that the biggest and most immediate difference came when I switched to Amzoil. I had the break in oils, then went to Syn3 the second time, basically no change, except for the progressive improvement with time. Amzoil made a significant and immediate improvement in this regard.
Old Jan 6, 2012 | 08:54 PM
glock221's Avatar
glock221
My 2011 Fatboy did the same thing. Got better around 500 miles, and almost completely went away by 1000 after I changed to Harley Syn. oil. I have about 4300 miles on it now no issues.
Old Jan 6, 2012 | 09:04 PM
sagebrush1976's Avatar
sagebrush1976
Temperature plays a big role in the issue.....or non-issue. I agree with TORQUEY......Amsoil made a world of difference in my bike too. Once you get a few "break in" miles on the new ride change the primary to Amsoil and you'll never look back.
Old Jan 6, 2012 | 09:37 PM
christian103"'s Avatar
christian103"
Amsoil is good stuff...when I started using it my shifting felt much smoother and quieter.
Old Jan 6, 2012 | 09:59 PM
Fatbob usmc EOD's Avatar
Fatbob usmc EOD
I had this same problem when I bought my 12' Fat Boy Lo back in November. Now that I have about 1300 miles on it, it's not as bad and getting a little better. I've found a good way to get into neutral for me is put it in first and kind of jab my heel down on the heel shifter. I had them put regular dino oil in it at the 1000 mile service but I'm switching to Mobil 1 V-twin when I do my 5000 mile service. I'll see if that helps or not.
Old Jan 6, 2012 | 11:10 PM
BikeJunkie225's Avatar
BikeJunkie225
6th Gear
my '12 lo does it only when first crank and dont let it warm up, now i always let it idle for a few minutes and let the rpms get down, never had a problem since, only have 900 miles .....as far as finding neutral shift into first and then upshift into neutral with your toe and it's alot easier b/c you have way more control
Old Jan 6, 2012 | 11:17 PM
BassCatcher's Avatar
BassCatcher
Yeah, as the others have said that is not that uncommon. It took about a 1000 miles until my Heritage would slip into neutral with no effort.
Hell, now that I think about it, my gas cap was hard to get off at first as well.
