I am going to put the SE 204 cams in my 06 FXST. Bike only has 6K miles on it. Do I need to replace the lifters when I install the cams or am I ok with original ones.
Thats a toss up, but if it were me I would. 6k on an '06 = lots of short trips. On most I would say no but if nothing else the age of them too. I'm sure others will chime in on this too
Interesting numbers you have there, are you riding around at 5000 rpm's with an average of 45 mph ?
Rpm's are measured at the crank, since we are dealing with a 4 cycle engine, the cams rotate once per two crank revolutions. Possibly I didn't understand your numbers?
Your lifters are good but replace the inner cam bearings with Timken B148's,writing facing out, about $15. If you're retaining the cam plate, r&r the oil pressure spring with a Baisley LMR-002 spring ($13) to increase oil pressure. Are you taking the rocker boxes off or using adjustable push rods?
I gotta ask. Does that spring raise oil pressure by restricting flow. I was under the understanding that a Twinkie's lubrication system was based on the idea of high volume low pressure. Please explain why. I am changing my cams in a couple of weeks and will do this mod if you can tell me why.
Thanks
