Trans. fluid
Old Jan 28, 2012 | 07:29 PM
zworld's Avatar
zworld
Default Trans. fluid
I would like to change my trans. fluid tomorrow. Whats my options @ auto zone or Walmart. Manual just says a part # doesn't tell much else. Thanks
Old Jan 28, 2012 | 07:42 PM
checkers's Avatar
checkers
May want to do search, hundreds of posts on this. I use Mobile 1 Syn 20w50 in all 3 holes for several FL's over many years/miles, no problems. I assume a "B' motor on your bike. The drain plug for the trans is up between the 2 shocks, cant see it, must feel for it. Do not remove the casting nipple plug forward of the shocks, that is not the drain plug. 1 qt will do when filling. Wally and Auto zone both stock the above oil, $10/qt
Old Jan 28, 2012 | 08:25 PM
ia2189's Avatar
ia2189
With those two options, can't go wrong with Mobil 1 20w50.
/thread
Old Jan 28, 2012 | 08:39 PM
S.D.M.F's Avatar
S.D.M.F
1 qrt of Redline Shockproof Heavy.....awesome stuff. Will make shifts easier and quieter too.
Old Jan 28, 2012 | 08:52 PM
colonelangus1's Avatar
colonelangus1
yup its syn and made for v-twin transmissions they also make awesome syn primary oil..redline makes great application specific products
Old Jan 28, 2012 | 10:15 PM
Sgt_Jim's Avatar
Sgt_Jim
I actually posted about this in the Engine Oil section, and after getting an answer to my post, and also reading through some of the many other posts about it, I'm going with Lucas Oil 85W140.. seemed like the consensus was over there that that is good stuff, and only $9 for a quart at PepBoys or somewhere
Old Jan 28, 2012 | 10:18 PM
Shredding rubber's Avatar
Shredding rubber
Anther vote for shockproof. Motor oil is for engines. Not trannies. And oil companies make a product for both. I will stick to shockproof or royal purple 70-90. Your results may vary
Old Jan 29, 2012 | 03:01 AM
nikonf8's Avatar
nikonf8
Default fluid
i use the red line in my tranny
Old Jan 29, 2012 | 06:15 AM
Youngneg's Avatar
Youngneg
Another vote for redline shockproof......
Old Jan 29, 2012 | 06:49 AM
Captain Itch's Avatar
Captain Itch
Sponsor
We use Bel Ray 85-140 in our bikes with probably close to 140,000 miles..Good stuff.
__________________
www.Captain-Itch.com
