Just curious. I switched to Shockproof in my 2011 Fatboy. I've found it definately upshifts better and nuetral is easy to find but, I swear sometimes it bangs downshifts hard,especially from 3 down. Make any sense??
Maybe you're just downshifting too early? They definitely clunk louder when you downshift at higher speeds and quieter/smoother at lower speeds.
Hey thanks all, just grabbed up the mobile since I was there at walmart. What kind of wrench are you using to get in there, 3/8th socket wont get in there, what do you use? an allen wrench?
Check the 2nd post: Drain bolt is located between the shocks. You cant see it, but you can feel it. Drain bolt is an allen socket in the center and a hex head on the outside. You can use a socket or allen socket on a 3/8" extention. I remove the drain bolt with a socket and reinstall by install bolt on an allen socket installed on an extension and feed it up between shocks being carefull not to cross thread. The bolt stays straight better when mounted on the allen then in a socket. I dont remember the sizes, feed a couple sizes up in there on an extension, and you'l get it.
