Fatboy fluids question
Old Feb 12, 2012 | 08:51 PM
94-Sporty's Avatar
94-Sporty
aparently it is better than the HD factory oil, but not much. A buddy of mine is an amsoil dealer, I will get some. not sure that will fix the problem though.
Old Feb 12, 2012 | 08:56 PM
TORQUEY's Avatar
TORQUEY
Originally Posted by OWOF
I wouldn't put castrol in my hd
Amsoil oil study II
If u don't wanna read the entire study, look at the last comparison chart on pg 24.
Amsoil is pricey, so I run Mobil 1 syn.
Amsoil goes in my scoot. I save the Mobil 1 for my lawn mower and air compressor.
Old Feb 12, 2012 | 08:59 PM
outgood's Avatar
outgood
Mobil 1 syn ranks 2nd to amsoil, (#2 out of 17 oils) so I'm sure ur lawn equip is happy.
Old Feb 12, 2012 | 09:09 PM
94-Sporty's Avatar
94-Sporty
OK so point taken, now that I am back working, next oil change gets better oil.
Hey OWOF, how long have you been with the Daytona BFs? I hear your house is open to the public on weekends, One of these days I will make a weekend trip over. Would love to talk to you about the MC if it's not against the by-laws
Old Feb 12, 2012 | 09:11 PM
94-Sporty's Avatar
94-Sporty
I guess I'll do the red tranny and UV dye thing to determine what it is I am seeing.
I also remember that last couple of times I have used engine degreaser on the bike, underneath the motor...I dont see how that could affect it though.
Old Feb 12, 2012 | 09:14 PM
outgood's Avatar
outgood
Public is always welcome. Always look forward to mtg new friends.
Old Feb 12, 2012 | 09:40 PM
Shredding rubber's Avatar
Shredding rubber
Red line shockproof is pepto bismol looking and is what I use in my tranny. Or use royal purple 70w-90. Both are different colours.
Old Feb 13, 2012 | 06:28 AM
Notgrownup's Avatar
Notgrownup
Castrol is fine...as long as you change it....Drink the Kool aid if you want...Not saying Amsoil ain't good...i have used it but if you change your oil regularly any 20w50 or 15w50 either Auto or V-twin oil is fine....remember it doesn't share the primary or tranny like metrics do so any Motor oil in that weight will be fine...Primary and tranny??? I now just use HD formula Plus... tried all the others and at 68000 miles in 4 years the bike works, shifts behaves whatever... about the same... Again...just MAKE SURE you change it....
I now use 15w50 full syn from NAPA...3.99 a quart sometimes...i change it between 4000-5000 miles...
Old Feb 13, 2012 | 06:59 AM
94-Sporty's Avatar
94-Sporty
ok. so if I put shocvkproof in my tranny, can I put royal purple in my primary without it causing any problems...I know with stock HD lube the Primary / tranny fluids are interchangable?
Notgrownup, I change my engine oil every 3000 miles and I do primary and tranny every other oil change.
Old Feb 13, 2012 | 09:28 AM
outgood's Avatar
outgood
Originally Posted by Notgrownup
Castrol is fine...as long as you change it.....
Viscosity Index: Castrol ranked 2nd to last out of 17 brands
Viscosity Shear Stability: Castrol ranked 3rd to last out of 17 brands
Rust Protection: Castrol ranked last out of 17 brands
High Temperature / High Shear Viscosity: Castrol ranked 4th to last out of 17 brands
Wear Protection: Castrol ranked 6th to last out of 17 brands
Oxidation Stability: Castrol ranked 6th to last out of 17 brands
Foam Control: Castrol ranked 6th to last out of 17 brands
I understand oils have to meet SAE requirements etc, but their V-twin oil is poor by comparison. Realizing the temps HD's run I' would advise against it. I'm not an expert. Castrol braggs about thermal breakdown protection and failed miserably on the viscosity test. And It didn't do well on the wear test. I ride the hell out of my bikes, and frequently change the oil. But if an oil is going to fail under certain conditions, it doesn't frequent changes may not prevent damage.
I know a lot of people swear by RP. I tried it in my Supercharged car and within a week noticed purple drips under it which became progressively worse every few days. I removed it under advice of the guy that built the superchargers and worked for GM, and after removal, it sealed back up and no more leaks. Just my experience.
