Front brake master cylinder help
Old Feb 20, 2012 | 02:36 PM
Hippiebeads's Avatar
Hippiebeads
Default Front brake master cylinder help
I have a chance to get a great deal on a 11/16 bore chrome front master cylinder for my 2005 Deluxe.Single disc master cylinders are 9/16 bore.Can this cylinder be used and what changes or concerns would be caused or created by using the 11/16 cylinder.Any help would be great,thanks.
Old Feb 20, 2012 | 04:21 PM
oct1949's Avatar
oct1949
Pheewwww.. Are U now having problem with Ur brakes?????????
My stock brakes have always done me just fine..... if U need the feel for more brakes... then goooo for it...
Old Feb 20, 2012 | 05:16 PM
Silver Ghost's Avatar
Silver Ghost
If you go to a 11/16 you will have greater squeezing effort, and less braking. The bigger the bore, the more fluid it pushes, but at a lower psi, generally 11/16 and 3/4 bores are for dual caliper applications.
Can you use it? yes, I have a 3/4 bore on my bike, and it sucks, I didn't put it there, and I plan on a 9/16 or 5/8 bore cylinder this season.
Old Feb 20, 2012 | 10:31 PM
HolePuncher's Avatar
HolePuncher
Just the opposite. A smaller bore will provide more pressure at a lower level of lever force. If you put a bigger bore master on you will notice that it takes a stronger squeeze vs. the smaller bore to achieve the same effective braking.
Old Feb 21, 2012 | 06:52 AM
cwsharp's Avatar
cwsharp
Hole puncher and silver ghost are saying the same thing... they just don't know it <grin>.
They both are correct. You will in effect lower the pressure at your caliper. Therefore it will take more lever pull to get the same amount of stop. Not a good thing for a front brake... it is the brake that does the most to stop your bike if you use it correctly. OTOH... it will give you more 'feel' between starting to stop and locking up.
C#
FlaTriker
Jul 31, 2014 02:11 PM
Roadkill73
Jan 19, 2014 10:45 PM
1982DSB
Apr 5, 2010 04:41 PM
bensonjv
Wheels/Tires
Sep 21, 2009 07:57 PM
Dustmaker
Dec 29, 2008 03:13 PM
