Any ideas?
Old Dec 20, 2006 | 01:41 AM
WARG's Avatar
WARG
Default Any ideas?
Hey guys,
I have a skull gas cap medallion on my stock gas cap. I just changed it out for the billet skull gas cap so I want to put the medallion on my air wing horn cover. I have seen a few of these on ebay that cost like $100.00. I already have the horn cover powedercoated black and I just want to attach the medallion which I already have. Any suggestions on how to attach it? I thought about drilling a tiny hole in both and using a very small screw and nut. However if I can find an adhesive that will work I would rather go that route. It will need to be something that will not damage the powder coat, can withstand a lot of vibration, and is water resistant.
I am also needing to reattach my chrome swing arm inserts that fell off. This seems to be very common from reading on the forum, so suggestions for attaching them will be appreciated as well.
Old Dec 20, 2006 | 09:12 AM
Cruiser 1970's Avatar
Cruiser 1970
Default RE: Any ideas?
HiWARG, I've used 3M Molding tape with good results. You can find it at any auto parts store and I've even seen it at Lowes. It comes in different lengths and widths and is not very expensive. You might also try epoxy.
Old Dec 20, 2006 | 10:43 AM
Deuce Bigelow's Avatar
Deuce Bigelow
ORIGINAL: Gundog
the 3M tape is the way to go!
Old Dec 20, 2006 | 01:53 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Rather than use the tape I would go the epoxy route. clean off the two surfaces with a good degreaser/wax remover and use a little bit of JB Weld with a c-clamp to hold get themtogether tight for 24 hours. Just don't use too much of it or it will seep out from underneath.
If you drill a couple of holes in the horn cover behind the emblem. It willsqueeze some through and you can usethat and any left over tospread around the holes. Once that stuffcuresit will never come off, even if you soak it in gas. So make sure its straight or you'll never be able to fix it.
Old Dec 20, 2006 | 03:20 PM
skips69's Avatar
skips69
The 3M double sided auto tape (used for emblems etc.) is good stuff. Clean areas well, lightly clamp the parts for 30 seconds - should last as long as you need it to.......
g8rgym
Aug 29, 2010 05:10 PM
WARG
General Topics/Tech Tips
Dec 20, 2006 01:52 AM
dawg
Oct 13, 2006 12:43 PM
atomic
Jul 21, 2006 08:21 PM
Primo
Dec 12, 2005 01:32 AM
