HELP!!!! Exhaust brackets for 1994 Fatboy
[IMG]local://upfiles/22167/29C721B697A4426EB59180DDD90CF72A.jpg[/IMG]
94 FLSTF
VH Hi/Low pipes
The bracket your drags were using probably wasn't the "stock" bracket, meaning the OEM bracket.
Sounds like VH is telling you that you need the original OEM bracket.
Funny, I can't find a hi/low version for that pipe on their site.. point me to it if I'm missing it. I can only see the straightshots, and straightshots HS (heat sheild version).
Gotta love JP Cycles.. You pay full retail there but they got a lot of info... Checked their catalog, the online catalog doesn't say anything but their paper catalog version says:
"Note: When mounting high/low system on FLSTC, FXST models, rear mount must be purchased. Use OEM 65522-91 or 440-521. Used on FLSTF."
.. ok so I looked up 440-521.. That is a chrome version of the oem.. $99 You can get the black powdercoat oem part over the HD dealer parts counter for a bit less I imagine.. say $45-75.
Take a look at http://www.jpcycles.com/catalog/2006...alog/0227.html
Search for 440-521 in middle of left column.. Look like something that will work? probably attaches to the swingarm area it looks like. The newer version on TC's bolts to two bolts above and below the swingarm bolt.
Hope I helped.
Good luck.. I hate parts delimnas.
