Fatboy LO rear suspension question
Old Mar 3, 2012 | 04:35 AM
thewholehog's Avatar
thewholehog
Default Fatboy LO rear suspension question
What exactly is the rear suspension set up on a Fatboy Lo?
I know its lowered but how? Lowering bolts? Different shocks? Different mounting bolts?
Thanks for any answers
Old Mar 3, 2012 | 09:39 AM
Sgt_Jim's Avatar
Sgt_Jim
I think the Lo has slightly shorter bolts, and a lower-profile seat.. but they're the same shocks
Old Mar 3, 2012 | 10:13 AM
Misbehaven's Avatar
Misbehaven
Not sure of the difference but the part numbers are not the same. The Lo bolts I would think are longer. That would make the Lo Lower.
Fatboy PN# 54508-00B
Fatboy LO PN# 54549-04
Old Mar 3, 2012 | 01:19 PM
tmitchellof PG's Avatar
tmitchellof PG
On the Deluxe and my 2005 SE Fat Boy they use different shocks, so I just assumed they did the same on the LO.
Tom
Old Mar 3, 2012 | 07:43 PM
thewholehog
Are those pt # for the shocke themselves or the bolts?
So you think the shocks are the same as other softails but the bolts are different?
Could you change the bolts to give it the same rear suspension as the standard height softails?
Old Mar 3, 2012 | 07:45 PM
thewholehog
Tom
I thought the shocks were different, but wasn't 100% sure.
Old Mar 3, 2012 | 07:48 PM
thewholehog
Thanks Sgt Jim, do you know if those bolts you are talking about can be changed to give the LO the same ride height and suspension travel as the standard Fatboy?
Old Mar 3, 2012 | 09:07 PM
RedNose44's Avatar
RedNose44
I would assume they would, but if not there are aftermarket companies that make adjustable ones. I have them on my springer and can adjust up or down a little over 2".
Old Mar 4, 2012 | 04:45 AM
thewholehog
OK so far we have some votes for "different shocks" and some votes for "same shocks with longer bolts"....
Anyone able to shed a little more light on the subject?
Thanks.
Old Mar 4, 2012 | 05:25 AM
Benway's Avatar
Benway
Thanks.
The way Harley reuses parts they gotta be the same shock with longer bolts. What this means is you should be able to get in there and adjust them back to fat boy height.
