Question about gas!
Old Mar 6, 2012 | 07:51 PM
Pistonbroke800's Avatar
Pistonbroke800
Pipes wont make a difference for fuel quality needs. Its when you start adding a bunch of compression or advancing timing or adding boost. Things like that require attention to octane ratings.
Old Mar 6, 2012 | 07:57 PM
Newfoundlandsoftail's Avatar
Newfoundlandsoftail
Thanks!
Old Mar 6, 2012 | 08:02 PM
Deuuuce's Avatar
Deuuuce
Originally Posted by djl
There is no benefit to running premium fuel if you can run a lower grade and the engine doesn't ping. .
Not true regarding audible pinging. If the motor is tuned/compression ratio for premium, it will get better mileage than using 87 and make more power.
Not only do our bikes not have sophisticated knock sensors, if you can actually hear it ping over the exhaust, you've got issues.
Doesn't mean he can't use 87, but there are factors where 91+ is an advantage.
Old Mar 6, 2012 | 08:22 PM
Jim Kraft's Avatar
Jim Kraft
I run 87 all winter, and then go to 89 in the summer. Engine runs a little hotter in summer, and the higher octane helps to keep it from pinging.
Old Mar 6, 2012 | 09:23 PM
Newfoundlandsoftail
Thanks for the replies, Gettin hammered with snow here tonight hopefully wont be to long I can get her out and try some 87 to see if ill be fine for the trip!
wizardfitz
Sep 22, 2020 01:56 PM
Johnny Davidson
Aug 18, 2013 10:10 PM
Bob99
Sep 21, 2009 09:15 AM
ubreal
Sep 21, 2007 07:27 AM
yota
Jun 30, 2006 07:30 PM
