pcv toggle switch
Old Mar 4, 2012 | 03:42 PM
jlasoftail's Avatar
jlasoftail
Default pcv toggle switch
Could one of you guys give me some tips on what type of toggle switch to use, and best place to mount it to go between maps?
Old Mar 4, 2012 | 04:18 PM
beasleyiv's Avatar
beasleyiv
Check out the first post in this thread Any acc switch will work, no voltage is required. The PCV senses continuity only. Read the post carefully, he explains how to create a rich base map, and then use AT to run leaner for better mileage.
Old Mar 4, 2012 | 04:19 PM
beasleyiv's Avatar
beasleyiv
As far as mounting, I would want it somewhere you could flip it w/o taking your eyes off the road.
Old Mar 5, 2012 | 04:49 AM
jlasoftail's Avatar
jlasoftail
bump...
Old Mar 5, 2012 | 10:02 AM
fishcop's Avatar
fishcop
Default switch
I just got the HD switch set for the handle bars. It holds 3 switches, so I use one for the gps and one for the PC V. Probably could also get aftermarket from Kuryakin or other company.
Old Mar 5, 2012 | 05:15 PM
jlasoftail's Avatar
jlasoftail
That's not a bad idea, but I'd rather not get more clutter on the bars... Any other ideas?
Old Mar 5, 2012 | 06:38 PM
IDSTC's Avatar
IDSTC
How about on the back of the fork cover by the passing lamp switch?
mrfikser
Mar 22, 2011 11:08 PM
DrPlastic
Sep 25, 2010 09:33 AM
thumper05
Apr 10, 2010 03:22 PM
Sancho
Mar 26, 2010 09:06 PM
DrPlastic
Mar 16, 2010 06:58 PM
