Please help an idiot get his forks back on
Old Mar 11, 2012 | 06:29 AM
tincup64's Avatar
tincup64
Originally Posted by BrianG
Freezing the trees is going to make the holes smaller. That ain't gonna work!
You want to frees the fork tubes and heat the trees if you want to try this trick.
But as was said above, something isn't right. As soon as I loosened the pinch bolt, each fork slid out under its own weight.
If driving a flat-blade screw driver or chisel in the slot that the pinch bolt crosses doesn't do it, there's really something wrong.
your right on both counts. off to get new lower tree. thx everyone.
tin
Old Mar 11, 2012 | 08:45 AM
08Nighttrain's Avatar
08Nighttrain
If they were damaged that badly you probably should repalce the whole set uppers and lowers.
Old Mar 11, 2012 | 11:28 AM
magna's Avatar
magna
How did you damage the forks? If you've had a hard accident enough to bend the forks, it's a good bet you've damaged the trees.
Old Mar 11, 2012 | 12:20 PM
tincup64's Avatar
tincup64
roger that...just bought everything. upper, lower, bearings - next weekends project.
tin
rainsong
EVO
14
Nov 13, 2020 10:33 AM
Stew_FL
Audio Systems
May 21, 2018 02:07 PM
tas_todd
Apr 30, 2015 11:20 AM
StreetglideBrahma
Feb 22, 2014 05:09 PM
Csands
Apr 1, 2013 12:11 PM
