Bar problem
Old Mar 10, 2012 | 07:28 PM
Brutus01's Avatar
Brutus01
Default Bar problem
Ok so right now I'm really not happy. I got my BR bars on and the 1" section for the grips and controls are about 3/8" too long. I will have a gap and things won't mount flush to the 1.5" part of the bars. What should I do? Try to cut them off with something like a pipe cutter?
Also, the upper brake line for my ABS is too short and the fittings are not the same at the bottom that connects to ABS module. Can someone tell me the specs for the upper brake line so I can get the right one ordered?
I was hoping to be riding tomorrow but guess that's not going to happen. Pissed off!!
Old Mar 10, 2012 | 07:32 PM
jreichart's Avatar
jreichart
I cut mine with a pipe cutter when I did the internal throttle. Get a good one for cutting 1.5 or larger pipe. It takes awhile, but leaves a nice square edge.
Old Mar 10, 2012 | 10:19 PM
Joe What's Avatar
Joe What
Well count your blessing they are not 3/8 too short....right.. common sense should prevail and lead you in the direction to cut them to proper size.
caulk04
Sep 17, 2018 04:36 PM
Moogs
Jan 31, 2018 08:44 PM
94ruck
Mar 13, 2014 07:18 PM
stewy1200c
Feb 4, 2012 10:31 AM
Bingee
Mar 15, 2009 07:42 PM
