Clucth cable/housing problems?
Old Mar 16, 2012 | 11:02 AM
theidbreder's Avatar
theidbreder
Default Clucth cable/housing problems?
I chst swapped out my bars for a set of 14" Wild1's. I was routing and hooking up cables and brake lines last night when I found that the clutch cable wouldn't pull freely or far enough for me to get it in the clutch perch. I chcked and the middle adjuster is compressed and has no more room to give. When I took the cover off and put in the new cable I did not have to remove the C clamp.
Have any of you had this problem or any ideas of what it could be? thanks
Old Mar 16, 2012 | 11:12 AM
Talldog's Avatar
Talldog
When I did mine, it was pretty tight too. Try loosening the two screws that hold the handgrip on and rotating downward. That should give you enough room to get the Cable attached and then you can rotate it back up.
Old Mar 16, 2012 | 01:31 PM
theidbreder
I have my clutch perch totally off the bike and can't get it installed. I can't even budge the cable with a screw driver through the clutch loop (on lever end) for leverage. Yes, it is a new cable and was free before I installed.
Old Mar 16, 2012 | 02:44 PM
Redbeard719's Avatar
Redbeard719
Depending on the position of the ramp inside the right side clutch cover, you may need to back off the clutch adjuster (under the derby cover) to allow it to move.
Then, hook it all up, and mount the perch. Afterwards adjust clutch back to its original position.
Old Mar 16, 2012 | 03:20 PM
theidbreder
If I back off the clutch adjuster under the derby cover will I need to take the right side clutch/ramp cover back off for anything??
bjchaffin2
Jun 17, 2024 07:28 AM
Comfortably Numb
May 3, 2021 12:45 AM
rmtwrx
May 9, 2016 06:28 AM
HWill
Feb 24, 2013 09:26 PM
Coastiejosh
Mar 9, 2012 04:44 PM
