Ricor vs Racetech
Old Mar 16, 2012 | 10:41 PM
t stone's Avatar
t stone
Default Ricor vs Racetech
I have researched the Ricor Intiminators. Looks like a good product. I see that Racetech makes the imulator. Does anyone know what the difference between the two? Racetech is a little bit less in price. I have been around Racetech in the motocross world and they do some killer suspension for dirtbikes so I figure the imulator should be good.???
Stone
Old Mar 17, 2012 | 10:25 AM
fabrik8r's Avatar
fabrik8r
I have no experience with the RT Gold Valve Emulators, but i understand how they work and I've only heard positive results. The Ricor Intiminators are similar to the RT valves, with the addition of an inertia valve circuit, this feature provides a valve that seperates chassis input and wheel input, allowing greater resistance to "brake dive" while still offering great compliance. I have been modifying and tuning these for a few years and Have come up with a very good recipe, so far all users have been very impressed.
https://www.hdforums.com/forum/touri...rk-better.html
Old Mar 17, 2012 | 11:11 AM
t stone's Avatar
t stone
Thanks for the reply. Sounds like you have really put alot of work into making a great product way better.
Stone
Old Mar 17, 2012 | 12:24 PM
Jester750's Avatar
Jester750
Also for ease in installation. The Ricors just drop in.
The Racetech ones you have to drill and make modifications to the stock fork valving.
I went with the Ricors.
Old Mar 17, 2012 | 02:40 PM
Sgt_Jim's Avatar
Sgt_Jim
I have the RaceTechs, drilling out the damper tube was easy enough.. but they also want you to cut a spacer to fit in the top of the tube to compress the springs more (unless you buy their springs), and with that spacer, putting everything back together was a pain in the butt..but there's a noticeable difference in the front end the way the bike holds in turns better and going over small bumps isn't as stiff anymore
fabrik8r
May 18, 2024 02:47 PM
SixDD
Jul 31, 2018 06:40 PM
jluca
Jun 20, 2016 06:39 PM
adm
Apr 26, 2016 01:57 PM
marcparnes
Jan 18, 2014 07:36 AM
