Fuel pump Install?
Old Mar 20, 2012 | 09:44 PM
Forge's Avatar
Forge
Default Fuel pump Install?
Looking for some advice from those that have installed a fuel pump in a FI tank. Bike is 01 Fatboy. Pump came out as expected. I have taken out and put in a couple times. The articulated arm is retracted like it is supposed to be (marked to make sure it was retracted fully). Disconnect line is connected. Float is in correct spot.
It is as if something is keeping it from seating properly. It is about half inch from sitting flush (without gasket). Should I just push it down hard. Just don't want to screw it up (bend something)...that would make the great deal on tins not so good.
Thanks for any advice.
Old Mar 20, 2012 | 10:44 PM
Rakthi's Avatar
Rakthi
Are you trying to put the fuel pump in the tank you took it out from or into a "new" tank?
If it is a new-for-you tank, what year is it? Might be slightly different set up. Check the inside against the original tank to see if they are the same.
Old Mar 20, 2012 | 11:27 PM
Forge's Avatar
Forge
Default Tank
It is a new to me tank. Both tanks are 01 FI Fatboy tanks (new one has the 01 fi ID tag). These tins were run for about a hundred miles then the guy swapped them and put in storage. All the stickers are on it. I will check to make sure they look the same on the inside to be safe. When I took pump out of the old tank it was seated flush to the tank with the factory gasket.
Old Mar 21, 2012 | 12:06 AM
oct1949's Avatar
oct1949
Old Mar 21, 2012 | 08:12 AM
Forge's Avatar
Forge
Default Pump
Originally Posted by oct1949
found these on Utube...
Thanks. I had looked at those before installing. I thought for sure after watching that getting it in the tank would have been the hard part. Also searched the forum but nothing helpful.
Old Mar 21, 2012 | 02:36 PM
Forge's Avatar
Forge
Default pump
Wondering if I should force down and start screws.
Old Mar 21, 2012 | 03:01 PM
Mike NY's Avatar
Mike NY
Did it pop up when you removed all the screws?, if not then I wouldn't force it down....
Mike
NY
Old Mar 21, 2012 | 03:04 PM
soft 02's Avatar
soft 02
Mine always sticks up on the front right corner about 1/2 inch and I just push it down and bolt it up. You are fighting the spring are.
Old Mar 21, 2012 | 03:19 PM
Forge's Avatar
Forge
Default Pump
It didn't pop up. That is the one thing that scares me. It would be different if I had to just force down one side.
Old Mar 21, 2012 | 03:59 PM
oct1949's Avatar
oct1949
I've posted it few thousands times in here.
Our forun search it not all that good,,,
DO a Google search to find the answer to the Issue we're having...
U'll get a lot better/easier answer and it'll be a lot faster.
I really don't understand why with all the puter knowledge people we have in here that a lot more dont use the GOGGLE Search....
