Wire Extension Kit Size
Old Mar 21, 2012 | 03:04 AM
PearlWhiteGT's Avatar
PearlWhiteGT
Default Wire Extension Kit Size
I'm replacing my drag bars with some 14" apes. Can someone that has used Namz Extension Kit tell me what size I need to order to complete the swap? (4", 8", 12" 15")
Thanks!
http://www.namzcustomcycleproducts.c...07_up.html#top
Old Mar 21, 2012 | 04:15 AM
Brutus01's Avatar
Brutus01
I ordered the 15" kit just to be safe when I changed to the 14's apes on my Lo and I have way too much additional wire. I could have easily used the 8" extension. That being said, my stock wires were long enough to run the whole length of the new bars and I was able to plug the extension in at the bottom of the bars. I may push the extra wire into the bars instead of leaving it under the tank. I don't know what would be best or if it matters.
Old Mar 21, 2012 | 05:51 AM
SeMiGoD's Avatar
SeMiGoD
Personally, i cut mine in a staggered pattern, got extra wire the same color and soldered them together closing the wound up with some heat shrink tube. Came out perfect.
Old Mar 21, 2012 | 06:38 AM
2012Fatso's Avatar
2012Fatso
Im having the same issue. I have 16" apes with 4" risers but i dont know what size extention to run.
Old Mar 21, 2012 | 07:11 AM
Leech1107's Avatar
Leech1107
I put the 15" kit on my bike with 16" Gangster apes. The stock wires were long enough to run through the bar. I could have went with the 8" and would have been fine, but i did not realize the stock wires had so much extra tied up under the tank. On my Fatboy lo it is easy to hid the wires behind the nacelle.
I would say the check to see how much extra is tied up under your tank or be safe and go long.
Old Mar 21, 2012 | 12:08 PM
PearlWhiteGT
So 8" would be the way to go?
Old Mar 22, 2012 | 01:41 AM
PearlWhiteGT
Is it better to just buy a spool of wire & cut & solder rather than getting a extension kit?
Old Mar 22, 2012 | 07:23 AM
Leech1107's Avatar
Leech1107
the NAMZ kit is to easy to justify not using it. you probably could get away with using the 8" but again I would check first to see how much extra you have or just get the 12".
Old Mar 22, 2012 | 11:51 AM
PearlWhiteGT
I read that soldering the wires on a motorcycle is not good due to the vibration. Can anyone tell me if this is true???
Old Mar 22, 2012 | 04:21 PM
Nick's Avatar
Nick
Do you need one namz kit or one for each set of switches.?
