Help bonehead move!!!
Old Mar 22, 2012 | 08:20 PM
norcal's Avatar
norcal
Default Help bonehead move!!!
I lost a screw and it went in a little slot behind the primary. Do I need to take the primary off, not sure if u can even access the slot from the primary. 2011 deluxe
Old Mar 22, 2012 | 08:28 PM
Tx_Outlaw's Avatar
Tx_Outlaw
Got a pic of the slot you are speaking of? Believe I'd put a magnet on the end of a stick or something and try to prod around in there for it first.
Old Mar 22, 2012 | 08:49 PM
norcal's Avatar
norcal
I tried the magnet no luck can't load pic right now but it's where the rear of the tie bar goes down
Old Mar 22, 2012 | 08:56 PM
ghostrider69's Avatar
ghostrider69
What's a tie bar? Could it have fallen all the way thru to the floor and you just not notice it? Could it be hung up between the shift arm and inner primary?
Old Mar 22, 2012 | 09:00 PM
norcal's Avatar
norcal
That's what I meant it fell in the slot where the rear gear shift linkage goes down
Old Mar 22, 2012 | 09:07 PM
ghostrider69
If that's the case and you can't see it then you could use a small mirror to look down in there and see exactly where it is and see what it's going to take to get it out. No need to pull the primary covers.
Old Mar 22, 2012 | 09:10 PM
norcal's Avatar
norcal
I will try that
Old Mar 23, 2012 | 01:24 AM
norcal's Avatar
norcal
No luck do u think if I take the primary off I will find it? If so what is the process for taking the primary off other than un screwing it
Old Mar 23, 2012 | 02:13 AM
murd's Avatar
murd
Poke around with a surgical needle nose type clamp. The kind we use to use as a roach clip. Maybe you can grab it.
Old Mar 23, 2012 | 02:54 AM
Rakthi's Avatar
Rakthi
Do you have a jack? If so, jack up the bike and look from underneath ...
Have you moved the bike forwards/backwards? Maybe the blasted thing falls out if it is just lying on the belt
Taking the primary cover off is not going to help you. To get to that area you will have to take off the inner primary cover ... bit more to that than just unscrewing ... you're talking alternator, compensator, primary chain, clutch basket ... And all this for a little screw that might not even be there?
Have you looked behind the starter too? Are you sure the little thing fell between the transmission and inner primary?
I'd look again on the floor. Turn off the lights and use a flashlight parallel and close to the floor, anything on there will throw a shadow ... easiest way to find little bits that fall on the floor and then hide in the most inconvenient spot.
