Help bonehead move!!!
Old Mar 23, 2012 | 06:15 AM
NC D'LUXE's Avatar
NC D'LUXE
I've done that a couple times. I got lucky with a little magnet you can pick up at a parts store. Be sure it didn't fall all the way through to the floor, I realized that happened one of the last times after fishing around with the magnet with no luck. Like Rakthi said, try rocking the bike back and forth.
Old Mar 23, 2012 | 10:52 AM
oct1949's Avatar
oct1949
Son did that when he put on the shift linkage cover. .
Looked for an hr with a little shop mirror and several little shop mags and still couldn't find it.
Two days later he saw it over by his mower...
Old Mar 23, 2012 | 11:29 AM
Vikingur's Avatar
Vikingur
Originally Posted by Rakthi
Do you have a jack? If so, jack up the bike and look from underneath ...
Have you moved the bike forwards/backwards? Maybe the blasted thing falls out if it is just lying on the belt
Taking the primary cover off is not going to help you. To get to that area you will have to take off the inner primary cover ... bit more to that than just unscrewing ... you're talking alternator, compensator, primary chain, clutch basket ... And all this for a little screw that might not even be there?
Have you looked behind the starter too? Are you sure the little thing fell between the transmission and inner primary?
I'd look again on the floor. Turn off the lights and use a flashlight parallel and close to the floor, anything on there will throw a shadow ... easiest way to find little bits that fall on the floor and then hide in the most inconvenient spot.
Almost easier to tip the bike upside-down and shake it. After rocking it, the magnet, and Rakthi's flashlight trick, you could try a small set of mechanical fingers to grab it. How big a screw are we talking?
Old Mar 23, 2012 | 11:49 AM
Lundee's Avatar
Lundee
Just get a diffrent bolt. The one you lost will fall out someday. It's not going to hurt anything.
Old Mar 23, 2012 | 12:05 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Hot dayum...I like that input, never heard that before
Old Mar 23, 2012 | 03:21 PM
bronxbill's Avatar
bronxbill
I'm with Lundee; whenever I drop a screw or nut and can't find it I just use another one. If it fell out, you will eventually find it, if it didn't, it most likely will work its way out as you ride
Old Mar 23, 2012 | 04:12 PM
71FLH's Avatar
71FLH
Bingo! I lost one in the same place. As long as it doesn't interfere with the shifting, forget it.
Old Mar 23, 2012 | 05:09 PM
socal yankee's Avatar
socal yankee
Me too! Hahaha!!!
Old Mar 23, 2012 | 05:15 PM
norcal's Avatar
norcal
I'm just nervous it would mess something up while riding one day
Old Mar 23, 2012 | 06:25 PM
priceamp's Avatar
priceamp
You mean like flip you off the bike? You know, that someday you’re going die riding that bike right? Fact of life, odds, probability. Just kidding. But I am considering getting a tattoo that says “Road Rash Warrior” after hitting a deer last year at 60mph.
I too lost a small sheet metal screw in that same location several years back. Forget what I was doing, but it slipped out of my fingers. It happens. I figured if the bike still shifts (and it did), ride it. And if it fell down into the transmission sprocket, then the belt will flip it out sooner or later or the screw will just get munched. Go for it, but might want to wear your jacket :-).
Jonathon Beaudin
Shovelhead
Dec 26, 2012 12:42 PM
xwhyz1959
Aug 11, 2012 03:46 PM
JefFLH
Nov 16, 2010 05:18 PM
tags
Jan 17, 2010 11:48 AM
UNCLE SAMMY
Mar 30, 2007 10:56 PM
