TTS Error code 504
Old Mar 24, 2012 | 05:07 PM
Bushrider's Avatar
Bushrider
Default TTS Error code 504
I was able to get my ECM info on the screen and when I go to save it I get prompted for a file name and vehicle info. I hit OK after filling in all the blanks and the save progresses to about 50% and then the error appears: sometimes it's "502 ECM is quitting" and sometimes it's "504 uploading ECM quitting".
I checked all the connections and tried again with same result. The manual says it will do this if the ECM comm. bus has corrupted data from a PC or other add-ons like guages etc. The only thing I've added to this bike (beside a bunch of chrome, cams and fatcat) is a smart siren.
I really don't want to download a new calibration without having my stock settings backed up.
Anyone have any ideas?
Old Mar 24, 2012 | 07:03 PM
Rakthi's Avatar
Rakthi
Only thing I xan come up with is serial to USB cable. Did you get the one from TTS or did you use one you already had?
Some people had lots of trouble and errors using non-TTS cables.
Also, have you tried using another COM port on yr computer?
Old Mar 24, 2012 | 07:08 PM
Bushrider's Avatar
Bushrider
Yeah it's a non-TTS USB adapter.
I did try another com port; same result.
Thanks anyway.
Old Mar 24, 2012 | 07:15 PM
Rakthi's Avatar
Rakthi
I'd buy the USB adaptor from TTS in your case. You xan get is a bit cheaper at M&M's online shop.
Switching to the right cable sorted most errors people experienced on Australian forum
Old Mar 24, 2012 | 07:57 PM
Mike NY's Avatar
Mike NY
Not that this helps you but I thought I would shed some light on the USB to Serial adapter issues..
There are different types of Chipsets used inside these adapters. The ones with FTDI chipsets seem to be the ones that work.
The ones with the Prolific chipset usually do not work. They are considered a cheap version which is why you see varying pricing on all these adapters.
You can usually see which one you have by looking at the Device Driver info in Device Manager.
It seems Belkin uses FTDI but I can't confirm that all their adapters do. Maybe some of the older ones do not...
Mike
NY
Mike
Old Mar 24, 2012 | 08:16 PM
Bushrider's Avatar
Bushrider
Mike
NY
Mike
Thanks, Mike. You've probably helped a lot.
It is indeed a Prolific driver. I paid over $50 for this cable so I didn't think it was a cheapy but I'm pretty sure I now know what the problem is.
Thanks everyone.
Jim
chambers j
May 13, 2015 06:00 AM
SSTuner
Mar 12, 2014 06:24 AM
davidw221
46
Apr 3, 2012 10:34 AM
Bushrider
Mar 24, 2012 08:11 PM
Wide06
Oct 19, 2007 05:32 PM
