View Poll Results: What should I do ?
Keep doing what your doing. Take it easy and change the oil at $1k miles
33.33%
Change the Oil now and still take it easy till $1k Miles
0%
Run it Hard
7.41%
Run it Hard but change the oil now
22.22%
None of the above with explanation
18.52%
Turn the computer off and stop reading crap on the Internet
18.52%
Voters: 27. You may not vote on this poll
Breaking in a new motor Advice !!!
Old Apr 4, 2012 | 07:12 PM
jlasoftail's Avatar
jlasoftail
I was always told not to run syn in a new motor, I waited for about 20k, not that's all I use. As far as how to ride it, everyone seems to say something different, but for me after I bought it, and after the bigbore, I ran about 500km easy, then ran it like normal.
Old Apr 4, 2012 | 08:01 PM
tunaman's Avatar
tunaman
Dyno Bob suggested to follow the mototune process after a few heat cycles, and it makes sense. I went 30 seconds, 60 seconds, 3 minutes, then went riding and kept rolling on and off relatively hard up to 4k for the first 19 miles. I then let it sit overnight, and put another 19 miles (same method) the next day. The third day I took it for a longer ride, and continued to vary the throttle throughout the run.
The first 20 minutes is crucial to seating the rings and needs good accel and decel pressure while the crosshatch in the cylinders still have teeth.
I went with Mobil 1 as I always do, and changed out the oil and filter after 100 miles. Engine is running strong and pulls hard.
Roger
Old Apr 4, 2012 | 08:24 PM
poppavein's Avatar
poppavein
I think that depends on how well its been built. Metals and machining technology has increased to where cars like Corvettes leave the factory with syn.
Old Apr 4, 2012 | 09:39 PM
tbonetony06's Avatar
tbonetony06
I was told this long ago, its how I have handled every bike I ever had or broke in and I truly believe this too, to break in your bike how you are going to be riding it! If you ride hard, break it in hard. If you cruise, then cruise and break it in that way. I always did my 1st oil changes at the first 500 mile mark.
Old Apr 5, 2012 | 12:45 AM
Inspector 12's Avatar
Inspector 12
I have had both of my bikes broken in on the dyno. Basically the tuner first heat cycled the engine several times and then ran the bikes at progressive levels of throttle opening while building the maps all the while monitoring the temperature of the engine (which had cooling fans on it at all times). When the bikes came off the dyno there were still some limitations on how hard they wanted the bikes ridden and when they wanted the oil changed but the rings were seated and the parts had taken their initial "set".
Old Apr 5, 2012 | 12:52 AM
NorCalFBLO's Avatar
NorCalFBLO
I believe in this:
http://mototuneusa.com/break_in_secrets.htm
Old Apr 5, 2012 | 06:47 AM
Tampa Fatboy's Avatar
Tampa Fatboy
Roger
Always heard once dyno'ed engine was pretty much broke in, change the oil and get on down the road. After reading your post, which makes alot of sense, have to recalibrate my thoughts on the matter.
Old Apr 5, 2012 | 09:37 AM
Blk and Chrome's Avatar
Blk and Chrome
Roger
I did the same thing. I even use syn oil, many of the high performance new cars use it from the factory as do the CVO bikes. Never an issue even with the race motors I used for 10 years
Old Apr 5, 2012 | 09:44 AM
tibadoe's Avatar
tibadoe
I just went by what the manufacturer states in the manual. Has worked for 30 years so far with no problems. They designed, built them, and know them best.
Old Apr 5, 2012 | 01:26 PM
str8jacket's Avatar
str8jacket
That's my thinking on it. I always follow manufacturer's break in procedure for any engine break in, whether it's car, bike, boat, or recreational. I guess people that suggest something different that the MOCO recommended break in procedure reckon they know more than the engineers that designed the motors.
