best way to remove relectors?
Old Apr 16, 2012 | 10:39 AM
Forge's Avatar
Forge
Default Reflector
Hair dryer, Fishing line, and GooGone.
Old Apr 16, 2012 | 10:44 AM
jayc67's Avatar
jayc67
Plastic scraper, then you break the reflector plastic into sharp shards which you then use to cut your fingers all up til you get all the little pieces unstuck, then you use GooGone to get rid of the glue and blood.
Or at least that's how I did it.
Old Apr 16, 2012 | 11:02 AM
Tampa Fatboy's Avatar
Tampa Fatboy
+1 on the fishin line.
Should you use a goof-off product or anything similar remember to lightly rub it in saturating the adhesive once the reflector, badge, etc. are off. Then gently use a plastic putty knife, wooden popsicle stick to get the most off. Reapply the goof off and gently remove the rest of the adhesive with a cloth. If you rub too long or too hard you will screw the finish up. Afterwards any decent polish and buffin wheel bring the shine back.
Old Apr 16, 2012 | 11:28 AM
discodave's Avatar
discodave
I'm telling you man, if you use Terpentine it will come off in seconds with just the rub of your finger. No need to let it soak or anything. It'll be off in seconds.
Old May 3, 2012 | 09:46 AM
MrShifty's Avatar
MrShifty
Use dynamite. I hear that crap works wonders. Just waiting on someone else to post results first.
Old May 3, 2012 | 11:32 AM
shooker's Avatar
shooker
All methods above work.
But I prefer the hammer and chisel method
Old May 3, 2012 | 11:43 AM
beasleyiv's Avatar
beasleyiv
Heat gun on low, peel off. Roll off any extra adhesive. 5 minute job.
Old May 3, 2012 | 11:44 AM
silent bob's Avatar
silent bob
The same for the rear fender reflector? On my Deuce, the reflector is on the painted part of the fender. I want to remove it, but don't want to screw up the paint. Can I use goof off, turpentine, etc on the paint? I did the fishing line and goof off method on my front chrome forks and it worked great, but I'm afraid to mess the fender's paint up.
Old May 3, 2012 | 12:03 PM
Deadanimal's Avatar
Deadanimal
3M adhesive remover is by far the best for removing sticky crap left from reflectors and other badges and trim that I have found yet. I don't even bother trying anything else anyway!
I also invested in some plastic scrapers wedges and such for trim and stuff like that.
Old May 3, 2012 | 12:08 PM
jayrocker's Avatar
jayrocker
Like everyone says hair dry and fishing line works every time.
