Bleeder screw question...
Old Apr 19, 2012 | 08:31 AM
fatboy1729's Avatar
fatboy1729
Question Bleeder screw question...
Hey forum. Posted this before. Just replaced the front and rear calipers on my Fatboy. Bled the brakes using the Mityvac bleeder kit. No problem. But, cannot stop the fluid seeping out of the bleeder screws. And both the front and rear brakes are really spongy. Any help or advice out there. Thanks...
Old Apr 19, 2012 | 08:39 AM
Scratt's Avatar
Scratt
If your seeping fluid out you are also sucking air in = spongy. Sounds like the bleeders are not tight enough or cross threaded. Take them out check the threads and if they are ok run them back in and tighten again.
Old Apr 19, 2012 | 09:30 AM
JohnFlorida's Avatar
JohnFlorida
try some teflon tape
Old Apr 19, 2012 | 10:30 AM
CSS_FXD's Avatar
CSS_FXD
I would run and get some speed bleeders for it. My local auto value store had some in stock today. $15 for the pair. 3/8 24 is the size you should need. I had used a mity vac before and it was a pain. The speed bleeders are the way to go I hear. Can't wait to try them out on my train. Good luck!
Lowcountry Joe
Jul 22, 2019 06:33 PM
fatboy1729
Jul 17, 2017 10:37 AM
fatboy1729
Apr 16, 2012 10:32 PM
ashmarc
Apr 10, 2010 01:38 PM
jungleman
Wheels/Tires
Mar 15, 2009 08:01 PM
