Brake light troubles
Old Apr 19, 2012 | 08:59 AM
Yankees's Avatar
Yankees
Default Brake light troubles
I began installing the Kuryakyn Deluxe Panacea tailight last night. Easy plug-n-play job, went to test it and the brake light doesn't appear to be working. Turn signals work, taillight stays on but when I apply either the hand or foot brake I get nothing.
Just to rule out the new taillight, I reinstalled the stock taillight and sure enough no brake light from that either. I asked my wife and she said that my brakelight was working a few days before when she was behind me. Checked all the fuses and they appear to be fine.
I'm a bit confused on what exactly the problem could be or really where to start in locating it. Any advise or tips would be greatly appreciated.
Old Apr 19, 2012 | 09:43 AM
Hogpro's Avatar
Hogpro
Former Sponsor
It could be the brake light switches both front and rear. We have seen both go bad but not usually at the same time.
Old Apr 19, 2012 | 10:06 AM
Tampa Fatboy's Avatar
Tampa Fatboy
VOM would be handy, you wouldnt had have to reinstall the old light. My thoughts are since the wife said brake light was workin the other day is to concentrate on the plug and pins. Doubtful both barke light switches got together and decided to go on strike. Be interesting to what ya find tho, let us know.
Old Apr 19, 2012 | 11:18 AM
Yankees's Avatar
Yankees
I did visually check all the connections that I messed with and they all visually looked good. I'll check everything tonight with a VOM to see if there are any irregularities.
I also thought i would be fairly odd for both brake light switches to go bad at the same time. I got to wondering if maybe the brake light was actually stuck in the on position. The new tail light was really bright and I attributed that simply to it being LED but maybe it was so bright because it sensed the brakes being applied?
Old Apr 19, 2012 | 11:40 AM
osrblack's Avatar
osrblack
I had the same issue and it was my front break switch stuck on.
Old Apr 19, 2012 | 11:58 AM
Yankees's Avatar
Yankees
Were you able to just fix it somehow or just buya new one?
Old Apr 19, 2012 | 04:20 PM
Nostalgic07's Avatar
Nostalgic07
Probably a stuck or failed brake switch.
I have same problem, just haven't had time
to troubleshoot!
SIGMACJT
Electrical/Lighting/Alarm
Aug 3, 2021 10:22 PM
mike603
Jul 3, 2017 06:23 PM
HogFather
Feb 16, 2009 11:53 AM
HogFather
Feb 10, 2009 06:52 AM
sporty05
Sep 26, 2007 11:44 PM
