Don't know much about it, but there was a guy on here who did a Crossbones up as a flying tiger tribute. His Crossbones is now listed for sale on ebay. He has a pretty slick passenger seat/backrest set up that floats over the rear fender and bolts to the frame where the fender struts usually go.
Anyone know if the 150mm kit will fit a '93 fxsts?? Says it fits 2000 and newer, not sure if there is much difference between the 130mm swing arm and the 150mm.
So i got the 150 Lucky F*cker kit. its not a bad looking kit for its price, but there's a bit of work to be done. so far i had to chop a piece of the frame off, and the EFI kit uses a sporty fuel pump which is gonna be fun trying to wire up. I also have to figure out what to do w all the wires from the console which are no longer gonna be in use.
what about the fender itself? It bolt up pretty well? I am assuming the piece of frame you had to get rid of was the frame horns for the old rear fender? Also, is the mounting bracket already on the fender? I ask because it looks like your rear fender needs to "roll forward" a bit.
The fender bolted right up, no issues there and it fits like a glove.and yeah i had to cut the horns which is no big deal. all that is missing in the pic is the struts which they reccomend u weld on.
put the rear fender on my 91 fatboy then decided i didnt like it. i had a metal shop strengthen it and change the mounts to make it fit the older than 2000 bike and make it possible to carry a passenger. didnt really know which way i wanted to go with the seat so i scrapped the idea and the fender is currently in my attic.
