RPMs, Speed, Shifting
Old Apr 23, 2012 | 09:54 PM
KumaRide's Avatar
KumaRide
Lots of room for running the rpm's higher, shifting later. This is for our 5 speed.
MPH @ 4000 rpm
1 --- 32
2 --- 45
3 --- 61
4 --- 80
5 --- 95
MPH @ 4500 rpm:
Gear mph
1 --- 35
2 --- 50
3 --- 70
4 --- 90
5 --- 105
Old Apr 24, 2012 | 07:49 AM
kzoo's Avatar
kzoo
My 04 Heritage also tells me when to shift, but I usually run it about 5 mph more than you stated before shifting. IE 1 to 2nd at 25, 2nd to 3rd at 35 etc.
Old Apr 24, 2012 | 08:07 AM
heybaylor's Avatar
heybaylor
mine vibrates into the next gear when rev'ed
Old Apr 24, 2012 | 08:19 AM
MikeZ's Avatar
MikeZ
Originally Posted by Pete_80
+1... same here.
Me too. Sometimes up 5 mph, but in this range.
Old Apr 24, 2012 | 11:37 AM
08rock's Avatar
08rock
I like shifting at 2600 rpm and cruseing 2300 rpm
Old Apr 24, 2012 | 01:33 PM
NDBadlands4-2's Avatar
NDBadlands4-2
Those sound right to me.
Old Apr 24, 2012 | 02:36 PM
oct1949's Avatar
oct1949
Use this calulator from Big Boyz to figure Ur Speed Vs RPM's..
Its the best I've found on the net for Years..
MAKE sure Ur change U Yr of bike at the top....
http://www.bigboyzcycles.com/Gearratio.htm
Old Apr 24, 2012 | 06:11 PM
goats's Avatar
goats
considering the mods people do to their bikes (cams a/c exhaust etc) and the different driving habits, you will find speed/rpm to be all over the place.
i noticed this myself as i have paid attention to this subject...just so i could figure if i am doing things right or wrong :-)
stock 2011 blackline (6 speed 96B engine)
2600 to 2800 rpm seems pretty smooth for shifting
it is not often i see 4000 or more rpm as i usually dont have a need or want to (but it has happened)
other than that i am all over the place with shifting and cruising, partly mood :-) partly conditions...
and i drive them all.... twisty/sketchy winding roads, slow residential roads, secondary highways posted 80 km/h, to the 401 (main highway) posted 100 km/h (people often doing 120 to 130 km/h in the fast lane)
that is just on my way to work
if i had to pick numbers i would say i shift between 2400 and 3000 rpm in any gear.
i do know that 6 gear and 3000 rpm = 130 km/h give or take a little
Old Apr 28, 2012 | 08:23 PM
The88Beast04's Avatar
The88Beast04
The H-D manual for the bike tells you the shift points.
aka, at 40 I'm shifting into 5th gear and it purrs.
You don't need to wind up a Harley - it's got plenty of power nice and low.
Old Apr 28, 2012 | 09:02 PM
tbonetony06's Avatar
tbonetony06
1 thing to also consider and remember. You are now working and going with a totally new and different type of transmission too.
