shifting seems to slam
Old May 3, 2012 | 09:04 PM
Luvdoctor's Avatar
Luvdoctor
6th Gear
Default shifting seems to slam
my recently aquired 07 Deuce (4K miles) seems like the transmission slams hard thru all the gears. From neutral to first i can sometimes get it to click by pushing gently instead of kicking it down but second thru sixth it definately is a hard shift no matter how easy it try to change. Clutch adjustment needed or is this just normal? Fluid level is good.
Old May 4, 2012 | 12:04 AM
HLK07XL's Avatar
HLK07XL
Default Mine is the same I think
My '04 Deuce hits the shifts pretty hard. When warm/hot it is a little smoother than cold but still mostly "hit's" with very decisive shifts. No grinding or anything. Just fairly solid "clunks."
Old May 4, 2012 | 02:30 AM
tbonetony06's Avatar
tbonetony06
I would start with clutch adjustment and even though your fluid level is full, you said it is new to you, did you change the fluid? If you didn't I sure would and I would also go to a syn. base fluid too. That sometimes knocks that hard shifting out of there, shifts much smoother with a syn. fluid, IMHO!!
Old May 4, 2012 | 04:42 AM
Blk and Chrome's Avatar
Blk and Chrome
I would start with a clutch adj. Adj both the clutch and the cable, change the trans fluid to a 70-90-syn gear oil and that should make it shift better. One other thng to ck is the primary fluid, too full or thick will not allow the clutch plates to disengage fully. I would change the primary fluid to an atf and don't overfil.
Old May 5, 2012 | 01:47 PM
oct1949's Avatar
oct1949
anytime U buy used it always agood idea to go through a reg service, U never know how she's been treated or how much or little maintenance has been done.
Old May 5, 2012 | 01:54 PM
harleyheaven's Avatar
harleyheaven
I've got a buddy that has an 07 Duece and it's doing the same thing. 2nd through 6th shifts very hard. It's like hitting an anvil with a hammer, a loud almost high pitched sound. He's been trying to figure it out with no luck? I'm curious to hear what others may have come up with.
Old May 5, 2012 | 05:01 PM
FroggyFatBoy's Avatar
FroggyFatBoy
when i installed the SE compensator, 99% of loud clunk, chunk and 5th gr rattle disappeared.
07 FB
Old May 5, 2012 | 05:10 PM
cromagnon's Avatar
cromagnon
4K, that ain't even broken in yet. Drain the fluids and replace with Redline Shockproof in the tranny and Redline Primary fluid in the primary. You will see a difference. Good Luck.
Of course it's an 07. Did they not have compensator problems?
Old May 5, 2012 | 06:41 PM
Benway's Avatar
Benway
I thought that's how you tell it's a Harley...
Old May 5, 2012 | 06:55 PM
Deucedog's Avatar
Deucedog
Uh, this was first posted almost a year ago.
But, I'll play along.
Maybe it's just the 6 speed trans as my 06 Deuce shifts great. Very little 'clunk' when stationary and 'clicks' when on the move.
