Rocker C problem please help
Old May 10, 2012 | 11:33 PM
rockermailman's Avatar
rockermailman
1st Gear
Default Rocker C problem please help
When I bought my FXCWC it had the touring seat setup for fxcw. Also had a few little dents!! Now is it possible to use it on my FXCWC?? The fender would hit the bottom of seat/strut.. Just got my fender repainted and license plate holes filled..Please help any advice would be appreciated.. adjust shocks?????
Old May 11, 2012 | 12:06 AM
LaidInk's Avatar
LaidInk
ive never heard of this happening with the stock setup as the fxcw and fxcwc are identical minus seat / colors
Old May 11, 2012 | 12:35 AM
UT-rckr's Avatar
UT-rckr
I have mine lowered 1" in the rear and don't have that problem
Old May 11, 2012 | 12:45 AM
rockermailman
1st Gear
Thanks I thought so.. However i put the touring set up back on, went for a ride an seen a little ding in the clear coat!! where the old dents were! sucks cause my painter did one hell of a job on it! even did Bar and shield logo to match tank, an true flames around it.. Can having the FXCWC seat with the FXCW touring setup have anything to do with it? Thanks again
Old May 11, 2012 | 01:01 AM
Kowan's Avatar
Kowan
Pictures would help.
Not sure of your setup using the stock FXCWC seat with the strut system for the FXCW.
Old May 11, 2012 | 05:24 AM
Rocker_Dan's Avatar
Rocker_Dan
I use to run that set up, had it lowered 2" and never an issue...
Old May 11, 2012 | 06:58 AM
Rodzilla6's Avatar
Rodzilla6
I ran the FXCW seat on my FXCWC with no issues/bolts right up. It rides much better and is further down/back than the stock seat with the little jump seat under it...reasonable cost also. I'm switching to a danny gray seat now, but the fxcwc seat is a less expensive option and not bad. BUT, you may want to check ebay, "danny gray rocker seat". A bunch are on there and reasonable...plus you can get gel...don't miss the gel...my brother did and had to have it added...Rocker is a great bike/enjoy!
Old May 11, 2012 | 09:20 AM
Kowan's Avatar
Kowan
You guys ran the FXCW seat with the system as it was designed.
He seems to be trying to run both.
Old May 11, 2012 | 10:37 AM
UT-rckr's Avatar
UT-rckr
Seat should have nothing to do with the issue of the touring strut hitting the fender. Only thing I can think of is not having the proper bump stop? We really need some pics to go any further.
Old May 11, 2012 | 10:46 AM
Kowan's Avatar
Kowan
How is he mounting a FXCWC seat and the FXCW struts?
