Fat Boy pullback riser installation
Old Aug 1, 2005 | 03:52 PM
chunks's Avatar
chunks
Default Fat Boy pullback riser installation
Lookin at installing pullback risers on my 05 Fat Boy.
Anyone done this themselves and if so, how difficult was it?
Just wondering how much stuff I'd have to remove from the front forks
to make all the right stuff accessible.
Old Aug 2, 2005 | 02:25 AM
whiplush's Avatar
whiplush
Default RE: Fat Boy pullback riser installation
Just remove the tins from the backside of the forks and they'll give you all the access you need. You'll have to loosen the bolts that hold the windshield on to slide them out. I think there's one other screw on each fork tin. Its a pretty simple ordeal, go for it!
Old Aug 2, 2005 | 11:30 AM
2goldens's Avatar
2goldens
I put my 2 1/2" risers on a couple of years ago without removing the tins, just used a long extension. But either way, not really a difficult job.
Have since added Heritage bars to those same risers. Much more comfortable.
Old Aug 2, 2005 | 12:33 PM
srigas's Avatar
srigas
I installed 4 1/2" risers on my 05 fatboy. Easy to do, but I haven't really found a quality product yet. I have had two sets of Kuryakyn risers and both have stripped out even with my being extra careful. If you get a quality set you will enjoy the added comfort. I have since ordered a set from J & P cycles. Hopefully they will be better!
Old Aug 2, 2005 | 01:48 PM
chunks's Avatar
chunks
ORIGINAL: srigas
Are you over tightening them? I'm surprised that you went through two sets
in less than a year.
Old Aug 3, 2005 | 01:40 PM
mchaous's Avatar
mchaous
I have a question on pullback's. If I put 4 1/2 , 2 1/2 pullback risers on my 2004 FatBoy, will I have to re-work the wiring and brake lines. Or will the same ones fit?
Thanks Mark
Old Aug 3, 2005 | 03:43 PM
2goldens's Avatar
2goldens
With 2 1/2" risers and the more pulled back Heritage bars, the stock cables were perfect.
coldduck
May 17, 2023 08:30 AM
ilmanzo31
Jul 18, 2010 02:36 PM
jbg
May 15, 2010 09:32 AM
pa pa Ricky
Jun 13, 2009 07:55 AM
DaFatBoy
Mar 10, 2008 02:18 PM
