tire size
Old Jun 2, 2012 | 09:20 AM
zing73's Avatar
zing73
5th Gear
Default tire size
What tire size should. I get for a 21" wheel
Old Jun 2, 2012 | 09:22 AM
Redbeard719's Avatar
Redbeard719
Depends on the width of the rim.
If it's 21x3.5 - 120/70-21.
Oh, and welcome to the forums. Do take a bit of time to familiarize your self with the site. Searches are pretty helpful. For instance, this topic has been discussed frequently.
Old Jun 2, 2012 | 10:45 AM
F117ewo's Avatar
F117ewo
It also depends on the look you're going for and the amount of clearance you have on the front end. The skinny fender on my Springer limits my tire width a lot. I think I only have an MH90-21 on the front. 90mm is a pretty skinny tire!!!
Jake
Old Jun 2, 2012 | 11:07 AM
zing73's Avatar
zing73
5th Gear
yeah its for a softail deluxe im mouting them on a 21x3.5 rim so the 120/70-21 will look good or should i get a 90/90/21 tire better? also i have a 16x3.5 rear rim and wondering if i should go with a mt 90 B16 or go with a 150/80/16
Old Jun 3, 2012 | 08:57 AM
cwsharp's Avatar
cwsharp
No, I don't think so. A 90 is for a narrower rim I believe. You need to check the manufacturer's application guide if you haven't already. I also don't think you will like the look of a narrower tire on a Deluxe, but who knows...
C#
Old Jun 3, 2012 | 11:10 AM
NC D'LUXE's Avatar
NC D'LUXE
For the front go with the 120/70/21. Sure, you can stretch the 90 and some people do, but I wouldn't do it personally. The 120 will give you plenty of rubber and will fit the 3.5" perfectly.
I'm running an 18 rear but the 150/80 will fit the 16". Here's a good chart to use at hdwheels.com
Sinner77
Jun 19, 2014 09:36 PM
Milty
Mar 23, 2009 06:22 PM
GPHDXLC
Jun 30, 2007 11:25 PM
cajun883custom
Jan 21, 2007 05:36 PM
KG
Apr 2, 2005 10:32 PM
