Pulsing when squeezing front brakes
Old Jun 10, 2012 | 06:03 AM
Big Trev's Avatar
Big Trev
Originally Posted by Hogpro
It could also be that your pads are lower now and wearing unevenly causing this .
Just how are worn pads going to give the feeling that the rotors are warped?
Old Jun 10, 2012 | 06:26 AM
Scaredofrain's Avatar
Scaredofrain
Indeed how??????
The pads are static the discs are not!
Old Jun 10, 2012 | 06:27 AM
Big Trev's Avatar
Big Trev
Use a "Dial Test Indicator" to check for rotor run out.
Old Jun 10, 2012 | 07:49 AM
Smdugan40's Avatar
Smdugan40
+1 on the indicator you can pick up a Pittsburg dial indicator and a magnetic base at harbor freight pretty cheap, off Craigslist you could prob pick up a quality sterrett indicator cheap
Checking rotor run out is pretty easy with the right tools
Old Jun 10, 2012 | 12:38 PM
studiopeg's Avatar
studiopeg
OK one more time Am I in danger if I ride if as is right now with the front brakes pulsing (it isn't too too bad but I can definitely feel it)?
Old Jun 10, 2012 | 01:22 PM
Big Trev's Avatar
Big Trev
It sure wouldn't bother me
Old Jun 10, 2012 | 01:52 PM
Smdugan40's Avatar
Smdugan40
That's something that only you can decide IMHO I can't feel how bad it's pulsing, and I can't feel how well it's still braking, and most of all I can't feel how nervous it's making you feel at the helm
fwiw
Old Jun 11, 2012 | 11:26 AM
studiopeg's Avatar
studiopeg
Well since it isn't very bad I'm going ahead to Laconia and will have it checked out/replaced when I replace the scored back rotor.
Anyone heading to Laconia, come say hi. I'll be in the bike show at the Lobster Pount on Wednesday (in the rain), at the Train Station bike show on Thursday, and at the Opechee Park bike show on Friday.
Old Jun 11, 2012 | 02:24 PM
Hogpro's Avatar
Hogpro
Former Sponsor
You are not in danger as long as the bike stills tops fine. It is more of an annoyance having warped rotors. Enjoy Laconia.
Old Jun 11, 2012 | 02:41 PM
VETERAN75's Avatar
VETERAN75
If you only feel it when braking, and there is no sound of metal to metal scraping, high pitch squeeling, just a feel of wobble then you should be fine to fix later. Just use your rear brake more often. Be safe and have a good time.
wombat457
EVO
68
Mar 25, 2020 08:45 PM
619DYNA619
Sep 15, 2016 06:39 PM
FatboyDilbert
Jun 17, 2015 05:40 AM
rodney123456
May 3, 2012 07:30 PM
Dogwood
Mar 21, 2008 09:26 AM
