Calling all Springers!
Old Oct 19, 2012 | 02:09 AM
  #251
Torinstealth's Avatar
Torinstealth
Default My Bad Boy
The springers definitely have a unique feel. I love the look but we do sacrifice some handling prowess. The rubber bushings on my shock mounts were so dry they were crumbling so I went to replace it & found someone had way overtightened the top shock mount bending the mount & making it too narrow to get a new shock in there so I just left it shock-less. I think it looks even better but the front end is easily upset by successive bumps. And using the front breaks while leaning is not an option.
Old Oct 19, 2012 | 09:55 AM
  #252
Woffski's Avatar
Woffski
There are some bad *** Springers on this forum!!!! Awesome uys!!!
Old Oct 19, 2012 | 10:12 AM
  #253
HrdNox's Avatar
HrdNox
Thought you guys might like to see this..Wishbone replaces the flat front pieces from Paughco and DNA units. http://www.threetwochoppers.com
Old Oct 19, 2012 | 09:38 PM
  #254
evade49's Avatar
evade49
My 06 springer classic that is currently getting painted
Old Oct 20, 2012 | 04:02 AM
  #255
gnewman's Avatar
gnewman
Sweet! Are you changing color?
Curious how you like the pogo seat and where did you get it?
Old Oct 20, 2012 | 11:45 AM
  #256
SprungDave's Avatar
SprungDave
If there is handling prowess lost, it is really due to your model's steeper rake, combined with a narrow front tire. I would consider getting all of the ill-repaired components repaired/adjusted/replaced to pass judgement on the ride quality of a Springer. The wider front tire and shallower rake on the FLSTS(I) units exhibit none of the issues you experienced.
Ride safe.
Old Oct 20, 2012 | 11:51 AM
  #257
Mark_H's Avatar
Mark_H
Ride safe.
I have to back up Dave on this. I love the way my FLSTS handles to the point that I believe it handles far superior to my 11 street glide. Could be because I have many more miles on it and I am used to the geometry...
Old Oct 20, 2012 | 01:34 PM
  #258
2WHEELFEVER's Avatar
2WHEELFEVER
Old Oct 20, 2012 | 02:48 PM
  #259
Torinstealth
Ride safe.
I'm sure you're right, especially about the narrow front tire. When I use the front brakes even just a little bit while leaning into the beginning of a corner I can feel under-steer, the front end just wants to push out of the corner, but let off the brakes and it dips right back in. I'm asking too much of a two inch wide piece of rubber. It uses up a certain percentage of it's available traction to hold its share of the 620 lbs well 790 lbs with me on it against the momentum behind that weight. Asking it to also use some more of it's traction to slow that weight just puts it beyond the traction that skinny tire has available.
I very thoroughly inspected everything & I think everything (other than the missing shock) is in great working order. I'm sure the 17 years have taken a small toll on the springs but do you think they could've lost so much of their spunk as to harm my handling? I mean the bike has 11K miles on it & is a 1995 but it's been babied and the front end has never been taken apart or modified.
Very interesting to hear that your impressions of the springer are so different from mine. Maybe something is wrong with mine. I mean on a curvy road I could not keep up at all with my friend... He was on a 50cc scooter. Sure on the straights I caught him but he could brake so much later because his scooter is only 150 lbs and all the corners were banked even leading into them and it was hilly so I had to be so careful about braking early or I'd carry too much speed & not be able to slow down enough before I had to start leaning. It was still a blast, a curvy road through the woods is bliss but I'm glad no one was watching the puny scooter that had to wait for me to catch up. I just assumed all springers sacrificed this much handling ability in favor of the looks & lack of need of maintenance.
Old Oct 20, 2012 | 04:42 PM
  #260
hspring03's Avatar
hspring03
i can dive mine into corners with no issues. All of them... you need to get a shock back on there, and check the overall health of the front end. Fall away, neck bearings, tire balance etc..
