Hopefully an easy question.
Old Jun 10, 2012 | 09:51 PM
thephantomsfire's Avatar
thephantomsfire
Default Hopefully an easy question.
How can you tell if a bike is lowered. I have a softail standard and it seems like it sets pretty low. I bought it used and don't know a lot about it. If so, does that change what size tire you can put under it.
Old Jun 10, 2012 | 10:15 PM
QC's Avatar
QC
Pics please. But if you can't see any light tween the tire and fender, its been lowered. That is done with the shocks underneath. You change it by lengthening the front mounting bolts (lower), or shortening the bolt (higher). Just make sure you get the bolts the same length.
Old Jun 12, 2012 | 04:58 PM
epleeds's Avatar
epleeds
even if its lowered it should change the size tire you can put under it, unless maybe you go with a bigger rim then factory.
Old Jun 13, 2012 | 05:25 AM
Stretchman's Avatar
Stretchman
If it was done with the lowering bolts you can always adjust them.
Old Jun 13, 2012 | 07:48 AM
oct1949's Avatar
oct1949
By looking at it or measuring it.
Also see if it has a bolt kit on the shocks
U Talking wider or taller tire vs stock.??
azthunt
Oct 1, 2015 05:21 AM
skebert
Wheels/Tires
Sep 7, 2014 08:27 PM
Indian Drifter
Aug 4, 2013 08:47 PM
Jolia
May 6, 2013 11:48 AM
jeepkracker
May 7, 2009 06:20 AM
