SE-204 Cam ?
Old Jun 17, 2012 | 07:59 PM
Black Gator's Avatar
Black Gator
2012 FatboyLo. Rush 2" slip-on's. SE air cleaner base w/factory "football". SE super-tuner.....SE 204 cams.
It's all good.
Old Jun 17, 2012 | 08:51 PM
518Train's Avatar
518Train
Got 'em, like 'em.
Old Jun 17, 2012 | 11:28 PM
av8or's Avatar
av8or
I've got them and am happy with them. My bike ran ok with the map I was running before I got them. Since I have done a tune and it runs even better. The starter does seem like its working harder to turn the bike over, but so far no problems.
Old Jun 18, 2012 | 08:06 AM
TheTroupe's Avatar
TheTroupe
Originally Posted by Blk and Chrome
I've run 204's for 3 years and well over 15k and they are good cams. Had them in a 96 and 103, they pull hard. The only thing I would suggest is to run a 4 degree gear in it with a stock 96, makes the power come on sooner. Without it it comes on real strong at like 25-2800 rpm. It's more of personal perferance than anything.. They do have good sound too. I'm not getting into anything else about cams, but the 204's are very good cams, and yes they are still in there
I agree with Blk & Chrome on this except if you are going to run a 2 into 1 exhaust, in that case you don't need or want the +4 degree offset. The 2 into 1 will move the torque down the power band by 200 rpm.
The only issue, if you can even call it that, is that it needs to warm up before it will run well. My 88ci will blubber of the first two or three minutes. Other than that I have had zero complaints.
Old Jun 18, 2012 | 10:11 AM
oct1949's Avatar
oct1949
Default dyno sheets on SE 204's cams
Son had them put in his 07 Duece and 09 NT..
I've added the sheet for U so U can see what the cams do.
Hot little cam and good lope at idle for a 96'er,
Our dealer has installed Hundreds of them, it was their preferred cam pick for several Yrs..
As said above they also highly recommended and almost always installed the 4* advance gear to move the line to the left..
below is his dyno sheet of his 07 Duece with V&H's BR's 2-2's
The thumbnail below is his sheet of His 09 NT.. with V&H's BSL's.
Both have the SE's 204's with the 4* advance gear, tuned by the same master turner at the same dealer with the same machine. of course diff time.
U can see the pipes do make quite a diff...
The BR's 2-2 are better in the lower rpm's and flatter across the sheet Than the BSL's.
mja52403
Sep 3, 2010 03:50 PM
jlasoftail
Oct 16, 2009 07:00 PM
Kevin's_09FXDF
Aug 5, 2009 03:05 AM
cncfxstb
Feb 4, 2009 03:34 PM
cooldude
May 10, 2008 01:10 PM
