Fatboy will not stay started
Old Jun 19, 2012 | 01:52 PM
Tribe of Judah MM's Avatar
Tribe of Judah MM
Stage I
Default Fatboy will not stay started
When I go to start my Fatboy 2001 EFI it runs for about a second and dies. Would a bad battery cause this? I have replaced fuel pump, fuel filter, fuel pressure regulator and still it acts like its not getting a spark or gas. At this point I believe the spark is being affected somehow because I have replaced everything on the fuel. I just changed out the spark plugs so my guess would be either the ignition coil or bad battery. I know the battery is bad because it will not stay charged for more than a day but could that cause a problem?
Old Jun 19, 2012 | 07:41 PM
dub976's Avatar
dub976
A bad battery could cause it not to stay running. My first bike, ninja 250. Had the same issue. Bought a new one and was good to go.
If you know the battery is bad then replace it. Your going to have to anyways, so it's not a waste of $$$. Just one more thing to cross off the list
Old Jun 20, 2012 | 09:55 AM
oct1949's Avatar
oct1949
Crankshaft sensor can cause these symptoms too.
read this one.
https://www.hdforums.com/forum/softa...nk-sensor.html
Ur new but also doing a Google search will open the door to help U learn a lot if U use it.
Here is a lot more help for Ya also.
http://lmgtfy.com/?q=Harley+dies+after+starting
Old Jun 20, 2012 | 10:25 AM
jadlh's Avatar
jadlh
Maybe a stupid suggestion...but this happened to me once...is the fuel switch in the correct position? (On - instead of reserve)
hooter23
Mar 26, 2017 05:01 PM
troygalloway
Sep 18, 2016 09:57 PM
Mugsy666
Aug 3, 2016 08:19 PM
NomoreNomad
May 25, 2016 03:11 PM
BRUMM
Jun 26, 2013 04:37 PM
