Extended Cables Help
Old Jul 5, 2012 | 07:54 PM
Tunernetwork's Avatar
Tunernetwork
Thumbs up Extended Cables Help
Hello everyone, quick question for you.
I just installed a set of the Arlen Ness 10" mini apes on the bike. And I am about to order my new lines from Magnum Shielding. I just want to make sure I am good to go on my lengths before placing the order from your experience(s).
From measuring the stock cables that are still on the bike, and looking at the distance I will need to make them fit properly etc, It looks like I need to go 4"+ over the stock lengths.
So in total, here is what I am looking at:
- Throttle & Idle Cable 4"+
- Front Brake Cable (Swivel) 4"+
- Clutch Cable 4"+
I just want to get info from those that have done similar size apes and installed new cables. From measuring, this looks like I won't have any issues with binding, tightness, rubbing etc. I just want to make sure before I pull the trigger and order the cables. Any info, pictures, or other input is greatly appreciated!
My main concern was with the clutch cable really because I want to make sure I catch that angle it needs the cable to enter the controls at and not be too tight.
Thanks in advance!
Old Jul 5, 2012 | 08:51 PM
olongapo1's Avatar
olongapo1
Magnum Shielding employees have a wealth of knowledge. If you give them a call, they may be able to give you spot on lengths.
Berick
Dec 15, 2015 03:35 PM
SwiftyBKells
Dec 3, 2013 07:38 AM
KURT14
Apr 30, 2013 09:45 AM
redfish1028
Jan 17, 2011 11:46 AM
jskwarek
Apr 2, 2006 08:41 PM
