Hi all: Need a bit of help. I repainted my front brake reservoir this last weekend. However, when I went to reassemble everything I forgot how the brake line was routed in relation to the throttle cables. Can someone with a stock fatboy post a picture of your handlebars showing how the brake line / throttle cables route? There are really only two ways the brake line can be routed, either in front of the throttle cables or behind them.
I went to look at my 2002 Night Train, but the routing must be different. The brake goes to the outside of the tripple trees while the throttle goes farther toward the center.
I don't think it really matters. As you can see from the pic below (which isn't very good), the throttle lines and brake line are sort of twisted together (this is how it came, stock) until they separate at the rear triple tree cover. I currently have mine running behind my throttle lines, but in parallel (have them tied together with a zip-tie at one point) with my throttle lines until the brake line goes thru the guides bolted to the rear triple tree cover. Hope this helps.
EDIT: don't forget the guide at the bottom of the gooseneck. If you fail to run your brake line thru that last guide, it will rub the fender. I'm only reminding you because I would've forgotten had I not bolted the the guide back in as a place holder while I had the brake line off.
Thanks for the pic. Your routing looks identical to mine.
