Deuce died
Old Jul 26, 2012 | 01:41 AM
apendltn's Avatar
apendltn
Default Deuce died
I have just replaced spark plugs bc they were fouled out. Yesterday rode ab 60 miles then got off an ate, after that bike wouldn't start but I had lights on. Finally started up and made it ab a mile down the road and then it totally died, no lights or anything. Ended up having it towed home after spending ab an hour on the highway trying to fix it. Once I was in home I opened up the battery and it was bone dry (NAPA battery that was in it when I bought it). Could the battery have been the main culprit or do I have another big problem? Please help.
Bike is an 03 Deuce with ab 8500 miles on it.
Old Jul 26, 2012 | 07:16 AM
cwsharp's Avatar
cwsharp
Best bet is a new battery. Borrow a known good one and see if that doesn't fix the problem.
Old Jul 26, 2012 | 10:06 AM
Wide_Open's Avatar
Wide_Open
Agree with above, battery is the place to start.
Old Jul 26, 2012 | 10:10 AM
Mark_H's Avatar
Mark_H
A little more details would be useful. When you say it wouldn't start at first, what was it doing? Deadkey? Slow crank? Normal crank speed?
Old Jul 26, 2012 | 11:35 AM
RSymonds's Avatar
RSymonds
6th Gear
does a dry battery possibly mean an overcharging problem?
Old Jul 26, 2012 | 12:38 PM
Mark_H's Avatar
Mark_H
Or lack of maintenance, or a cracked battery.
Old Jul 27, 2012 | 06:13 PM
apendltn's Avatar
apendltn
At first it was cranking at normal speed then it would slow significantly. Then nothing "dead key" I guess. Could be I've ignored the battery, wasn't aware they only last 3-5 years.
Old Jul 27, 2012 | 06:48 PM
Liberator's Avatar
Liberator
Wow, if that bad boy was bone dry then it certainly hasn't been taken care of. That'll do it every time and once it gets to that point it's unlikely to ever come back. Absolutely get a sealed battery and put it on a battery tender if you don't ride it for extended periods!
Old Jul 28, 2012 | 06:02 AM
Redhill Phil's Avatar
Redhill Phil
Yeah once that battery is dry it's stuffed
Old Jul 28, 2012 | 11:57 AM
oct1949's Avatar
oct1949
Just got one of these this spring.
$40 less than HD and its made by the same company. its a GM and has two yr vs HD 6months warranty..
