Softail ABS brake line kit....
Old Jul 26, 2012 | 08:54 AM
mill3rk's Avatar
mill3rk
Default Softail ABS brake line kit....
Just wondering if anyone out there has used the LA CHOPPERS Cable and Brake line kit for the 11-12 softails with abs. I got the kit but the fitting for on the brake line that would connect to the ABS unit dos not make sense to me on how it would fit. Just wondering if anyone else had the problem or maybe I got sent the wrong line. Part# LA-8150KT-13B. The bottom ABS fitting is a 90 degree banjo that looks as if I connected it then the cable would loop out front of the frame into the path of the front wheel and not like the 90 degree banjo on the OEM cable.
Cheers,
Talldog
Touring Parts
Mar 17, 2015 05:22 PM
BOSOXFan
Oct 21, 2013 07:09 AM
Divr
Touring Parts
Sep 2, 2013 03:39 PM
Francis Bisson
Mar 21, 2013 05:53 AM
caleb7mm
Mar 22, 2008 07:44 AM
